Max Angle of Rod w/ Clay Ball: Rotational Problem 2
  • Thread starter Thread starter Anthonyphy2013
    Rotational
The problem involves a 75 kg rod and a 15 g clay ball colliding inelastically, with the clay ball sticking to the rod's tip. The conservation of energy principle is applied, equating initial kinetic energy to final gravitational potential energy and rotational kinetic energy. The discussion emphasizes the need to calculate the rod's moment of inertia and angular velocity after the collision to determine the maximum angle from vertical. Key equations include those for kinetic energy and gravitational potential energy, with a focus on the rod's pivot point affecting its potential energy change. The solution requires careful consideration of both linear and rotational dynamics.
Anthonyphy2013
A 75 kg , 34 cm long rod hangs vertically on a frictionless , horizontal axle passing through its cener. A 15 g ball of clay traelling horizontally at 2.2m/s hits and sticks to the very bottom tip of the rod. To what maximum angle , measured from vertical , does the rod ( with the attached ball of clay ) rotate ?
KE= 1/2 (m+M)V^2 , U= Mg(L-Lcosθ) , mvi=(m+M)(L/2-L/2cos)
Energy is conserved , Ei=Ef. Ei= 1/2(m+M)v^2 , Ef = Mg(L-Lcosθ) +(m+M)(L/2-L/2cos) or should i consider K rot as well ?
Start from before the collision - is the collision elastic?
The kinetic energy left after the collision turns into gravitational potential energy right - so what would be the rotational KE when the rod reaches it's maximum angle?
note: the rod is pivoted through it's center - how does it's grav PE change with angle?
inelastic collision . Thats I am wondering the kinetic rotational energy is concluded and I am wondering the kinetic rotational energy is 1/2IW^2 and I = 1/2MR^2 + (M+m)R^2 ? how can I find angular velocity in this case ?
You need to do conservation of angular momentum for the initial collision, use that ##\omega=v/r##
So at the instant just before the collision, the mass m (given) is moving at speed u (given) a distance r (given) from the pivot (the rod has length 2r) then it's moment of inertia is ##I_m=mr^2## and it's momentum is ##L=(mr^2)(u/r)## ... afterwards: the instant after the collision, the mass m is moving with a (different) tangential velocity v, which gives angular velocity for both the mass and the rod (since they are turning at the same rate). Note: moment of inertial of the rod is not Mr^2. Look it up.
The kinetic energy will be ##\frac{1}{2}I\omega^2##
