Max Bending Moment: Calculation & Formula
The maximum bending moment of 0.29 MNm can be calculated using standard beam tables, which provide pre-calculated values for various beam configurations. A correction was noted in the total weight calculation of the wall, indicating it should be 0.145 MN instead of 0.145 kN. The discussion also clarified the formula for calculating bending stress, emphasizing the relationship σ = M ⋅ y / I, where I is the moment of inertia. The dimensions of the beam's cross-section are crucial for ensuring that the maximum bending stress does not exceed 7.5 MPa. The beam's depth is suggested to be twice its width for optimal performance.
foo9008
how the author found the maximum moment = 0.29MNm ? is there any formula ? how to find it in this question ?
Of course there's a formula. That's what beam tables are for - too look up things like the maximum B.M. without having to work them out from scratch all the time.
Here is a set of typical beam tables:
http://www.awc.org/pdf/codes-standards/publications/design-aids/AWC-DA6-BeamFormulas-0710.pdf
Your beam is Figure 1, page 4.
BTW, the calculation of the total weight of the wall above has a small error. W = 0.145 MN, rather than 0.145 kN.
the shape is rectangular cross section , am i right ? why the moment shouldnt' be a(b^3) / 12 ? but , a(b^2) / 8 ?
The problem is trying to figure out the dimensions of the cross section of the beam so that max. bending stress is limited to 7.5 MPa.
Remember, in bending, σ = M ⋅ y / I
It is postulated that the beam supporting the brick wall is twice as deep as it is wide, or w = b and d = 2 ⋅ b, and I = w ⋅ d3 / 12 and y = d/2
