Max height of thrown object with 12m/s at 1/5 of height
An object is launched vertically with a speed of 12 m/s at one-fifth of its maximum height. The maximum height is calculated to be approximately 36.73 meters using the kinematic equation. The discussion highlights confusion regarding the interpretation of height fractions and the signs in the kinematic equations. It emphasizes that 1/5 is a fraction of the maximum height, not a specific height in meters. Clarification on the correct application of kinematic equations is crucial for solving the problem accurately.
brundlfly
An object is shot vertically upward and has a speed of 12 m/s when it reaches one fifth of its maximum height.
a. What is the initial speed of the object?
b. What is the maximum height of the object?
Free falling objects
I used the formula vf^2 = vi^2 - 2g(yf - yi) and got 144 = 0 + 19.6(1/5 - 0), I solved for 1/5 so I have 144/19.6 = 1/5 and got 1/5 = 7.35 meters. This times 5 yields 36.73 meters. This would be it for part b. But I am stuck on part a where I have to find the speed. Any advise on how to approach this? Thank you.
You got a negative value (because -2g(yf - yi) is negative), and then you probably thought "oops, the square of velocity can't be negative, so let's change the sign and hope for the best". It does not work that way.
You should have asked yourself "why did I get a negative value where only a positive one is possible? Where did I go wrong"?
Not really, the reason why I ended up with a positive value instead of a negative is because
144 = 0 - 2(-9.6)(1/5 height) = 144 = 0 -(-19.6)(1/5 height) = 144 = 19.6 (1/5 height). If you don't agree let me know.
The basic kinematic equation is ##v_f^2 = v_i^2 + 2 a(s_f - s_i) ##. Adapted to free fall, it is either ## v_f^2 = v_i^2 + 2g (y_f - y_i) ##, where ## g ## is then taken negative, or ## v_f^2 = v_i^2 - 2g (y_f - y_i) ##, where ## g ## is then taken positive. But you cannot have both the equation in the form ## v_f^2 = v_i^2 - 2g (y_f - y_i) ## and ## g ## negative in it.
yf is not 1/5.
When the speed is zero, the object has reached the maximum height. (h_max).
When the speed is 12 m/s the object height is 1/5 from this maximum height.
1/5 is not a height in meters (or other unit of length) but a fraction.
Saying that 1/5=7.35 m is nonsense.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
