How to find increasing and decreasing intervals of a biquadratic function?
To determine the increasing and decreasing intervals of the biquadratic function y = -x^4 + 18x^2 + 11, one must first find the first derivative, f'(x), and identify critical points. Creating a sign chart for the first derivative will provide clarity on the function's behavior. The resulting third-order equation from setting the first derivative to zero can be solved to find critical points, including a local minimum at zero. This method is effective and straightforward for analyzing the function's intervals. Understanding these intervals is crucial for graphing and interpreting the function's characteristics.
courtrigrad
Hello all
Given y = -x^4 + 18x^2 + 11 how would you find the intervals where the function is increasing and decreasing? Would you have to find f'(x) and find critical points?
Thanks
Yep, that's the most straightforward and surefire way to do it.
yes that is the way to go...
make a sign chart of the first derivative and you'll have all the info you need
marlon
Due to the biquadratic character of the function,the resulting 3-rd order equation (when setting the first derivative to zero) can be solved easily.
One of the solutions is zero and is a local minimum.
Daniel.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
