What is the maximum angular speed for optimal mixing in a cement mixer?
The discussion focuses on determining the maximum angular speed for effective mixing in a cement mixer, emphasizing that if the drum spins too quickly, materials will adhere to the walls instead of mixing. The radius of the drum is given as 0.68 m, and the relationship between angular speed and the forces acting on the materials is explored. The gravitational force and normal force are identified as key factors influencing when the materials will fall back into the mix. The concept of centripetal force is also highlighted as crucial to understanding the dynamics at play. Ultimately, the maximum angular speed must be calculated to ensure optimal mixing without material sticking to the drum.
toastie
In a cement mixer, cement, gravel, and water are mixed by tumbling in a slowly rotating drum. If the drum spins too fast, the materials stick to the wall instead of mixing. Assume the axis of rotation is horizontal. Calculate the maximum angular speed for which the materials will mix. Express the answer as the number of revolutions per minute. Radius = 0.68 m.
I have tried using angular speed = v/r = theta/t . I assumed that t was equal to 1 minute and the angle was 2*pi. However, this did not work.
The maximum angular velocity for which the material still mixes is when the material just falls down when it reaches the "top", maximum height, of the rotating drum. Which force makes the material fall? When the material just about sticks to the drum which force is equal to the mystery force that makes the material fall?
Okay, so I know that the force which pulls the mixture down is the gravitational force. I believe that the force which is the mystery force is the normal force. Thus, making g+N=0. I just before the mixture falls it would have a velocity of 0 or would it be the velocity the mixture is moving in based on the rev?
No the total velocity does not have to be 0 for the mixture to fall. Hint, centripetal force.
