Maximum Current in AC Circuit Problem
The problem involves a 200Ω resistor connected to an AC generator with a peak voltage of 10.0V, asking for the peak current at frequencies of 100Hz and 100kHz. The relevant equation used is V=IR, leading to a calculated peak current (Imax) of 0.05A for both frequencies. Participants confirm that the frequency does not affect the current in this specific scenario, making the question appear simpler than expected. The discussion emphasizes the straightforward nature of the calculation despite initial concerns about the frequency's relevance. Overall, the solution is validated as correct.
Sandbox.WeC
A 200? resistor is connected in series with an AC generator that produces a peak voltage of 10.0V. What is the peak current through the resistor if the frequency of the source is (a) 100Hz and (b) 100kHz
V=IR
I just plugged in the numbers and I arrive at a value of Imax=0.05A for both part a and part b. Is this correct? I am just uncertain if the question is only trying to lead me astray with the frequency values as they do not seem to play a part in this solution.
Hi Sandbox.WeC, welcome to Physics Forums.
You are correct.
Thanks a lot. This question just seemed... Overly simple.
