Maximum distance in orbit from center of a planet
The discussion focuses on calculating the initial speed \( v_0 \) required for a satellite to achieve a maximum distance of \( \frac{5R}{3} \) from the center of a nonrotating planet with mass \( M \) and radius \( R \). The conservation of energy and angular momentum principles are applied, with the relevant equations including \( E = \frac{1}{2}mv^2 + \frac{L^2}{2mr^2} + V(r) \) and \( V(r) = -\frac{GmM}{r} \). The angular momentum at launch is equated to the angular momentum at apogee, leading to the derivation of \( v_0 \) in terms of gravitational constant \( G \), mass \( M \), and radius \( R \).
  • Understanding of conservation of energy in orbital mechanics
  • Knowledge of angular momentum principles
  • Familiarity with gravitational potential energy equations
  • Basic proficiency in algebra and calculus
  • Study the derivation of orbital mechanics equations using conservation laws
  • Learn about the implications of angular momentum in satellite motion
  • Explore gravitational potential energy calculations in different orbits
  • Investigate the effects of varying launch angles on satellite trajectories
Students in physics or engineering disciplines, educators teaching orbital mechanics, and anyone interested in satellite dynamics and gravitational physics.
gcfve
Consider a spherical, nonrotating planet of mass M, and radius R, with no atmosphere. A satellite is fired from the surface of the planet with speed v0 at 45o from the local vertical. In its subsequent orbit the satellite reaches a maximum distance of 5R/3 from the centre of the planet. Use conservation of energy and angular momentum to find vo in terms of G, M, R.
E=[tex]\frac{1}{2}[/tex]mvr2+L2/2mr2+V(r)
so far all I have is a=GM/R^2, which I probably don't even need.
Have you got a formula for V(r)?
Also need to work on momentum:
Angular momentum at start = angular momentum at apogee
Well, L=mrv or L=mbv0
and i guess V=-GmM/r but i don't know how to use these at this point..
