Max Temp in Ideal Gas Transformation: 2490K
  • Thread starter Thread starter KingAntikrist
    Maximum Temperature
The discussion revolves around calculating the maximum temperature of an ideal gas undergoing a transformation defined by the equation p = p_0 - aV, with given constants. Participants note that the ideal gas law, pV/T = constant, can be used to derive temperature as a function of volume. It is suggested that substituting the pressure equation into the ideal gas law will help find the maximum temperature. However, there is uncertainty about whether the number of moles of gas is necessary for a definitive numerical answer. The maximum temperature options provided include values ranging from 2450 K to 2500 K, with 2490 K being a focal point.
KingAntikrist
Again, it's a translation, i don't know if it's 100% accurate in english
An ideal gas suffers a transformation under the law p=p_0-aV, p_0=10^5 Pa, a=\frac{10^6}{8,3} \frac{Pa}{m^3}. The maximum temperature on this transformation is: ...
A) 2450 K
B) 2500 K
C) can't be calculated (THIS IS NOT THE ANSWER)
D) 2480 K
E) 2490 K
F) 2460 K
\frac{pV}{T}= ct
The attempt? Nill...not even my physics teacher could solve this (private lesson with him). And i really don't have any ideea...
That aV is actually another pressure...
Substitute p(V) from the equation to the ideal gas equation to obtain T(V). For V>0, find max(T) :smile:
EDIT: I think the number of moles of the gas must be given for a numerical value of Tmax.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
