Yes, 86.2 N sounds like a more accurate answer. Great job on your solution!
  • Thread starter Medgirl314
  • Tags
    Force
In summary, a 15 kg crate with a coefficient of friction of 0.28 requires a horizontal force of 86.2 N to be accelerated at 3.0 m/s^2.
Medgirl314
561
A 15 kg crate rests on the floor. The coefficient of friction between the crate and the floor is 0.28. How much horizontal force is needed to accelerate the crate at 3.0 m/s^2?
Fnet=ma
m=15 kg
F-f=ma
F-[itex]M[/itex]N=ma
F-[itex]M[/itex]mg=ma
F=ma+[itex]M[/itex]mg
F=15*3+.38*15*9.8
F=81.16 N.
For a final rounded answer of: F=81.2 N.
This answer seems correct to me, could someone please confirm?
Thanks! :smile:
Fnet=ma
m=15 kg
F-f=ma
F=15*3+.38*15*9.8 (0.28 is the μ in the prob. statement)
F=81.16 N.
Thanks! :smile:
I don't get your result, even with μ = 0.28. Try your calculator again.
Oops, I thought I corrected that, sorry! Weird, I somehow mixed up the digits. Does 86.16, rounded to 86.2, sound better?
Thanks!
What does "May the Force be 81.2 N" mean?
"May the Force be 81.2 N" is a reference to the famous line from the Star Wars franchise, "May the Force be with you." The "81.2 N" refers to the unit of measurement for force, which is Newtons (N).
How is the force of 81.2 N related to the Force in Star Wars?
There is no direct correlation between the two. The force in Star Wars is a fictional energy field, while 81.2 N is a unit of measurement used in science to describe the amount of force applied to an object.
What is the significance of using 81.2 N specifically?
The use of 81.2 N is arbitrary and has no special significance. It is simply a unit of measurement that is commonly used in science.
Can the force of 81.2 N be measured in real life?
Yes, the force of 81.2 N can be measured using a force meter or scale. This amount of force is equivalent to the weight of approximately 8.3 kilograms on Earth.
Is there a connection between the force of 81.2 N and the gravitational force?
No, the force of 81.2 N is not directly related to the gravitational force. The force of 81.2 N is a measure of any type of force, while the gravitational force is a specific type of force that is exerted between two masses.
