Is It Safe to Use MCBs as Regular On/Off Switches?
  • Thread starter Thread starter M.Kalai vanan
    Switch
MCBs, or Miniature Circuit Breakers, can technically be used as on/off switches, but this practice is generally discouraged due to design considerations. While modern MCBs compliant with BS60898 can function for switching applications, using them as regular switches is seen as poor design. Older MCBs are not intended for frequent switching, which can significantly shorten their lifespan. Compliance with local standards, such as UL codes in the U.S., is essential when considering MCBs for switching. Ultimately, the decision depends on various factors, including the specific application and regulatory standards.
M.Kalai vanan
can MCB be used as normal on/off switch?
What's an MCB? What is the context of your question?
Assuming Molded Case (Circuit) Breaker - then yes, but it is clunky, heavy to switch. In a larger application the MCB can be the main disconnect switch.
MCB is common terminology here in England for Miniature Circuit Breaker and modern MCB's that comply to BS60898 can be used as functional switching for say lights but in the capacity of design of the installation this would be regarded as poor design and practice. Older MCB's you will often find are not designed as a functional switching device and the repeated switching will reduce its lifespan dramatically.
As the BS number I have quoted is a British Standard you will need to relate to your own countries coding system for the MCB you are discussing then, I believe America using a UL code then look up whether your particular device is compliant for frequent functional switching.
There's no Yes or No answer here as its down to several factors some of which I've touched on.
This is the best answer I can give with the info supplied.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
