Measuring Accuracy of a Trebuchet Project
The discussion focuses on measuring the velocity of a trebuchet at specific points along its arc for a physics project. The user has calculated initial velocities and distances but is uncertain about how to determine the velocity at a specific time, such as 0.1 seconds. The relevant equations for calculating velocity in both the X and Y directions are provided, emphasizing the need to incorporate the angle of launch and gravitational effects. The user seeks guidance on which distances to use for accurate measurements. The conversation highlights the importance of understanding projectile motion principles in the context of the trebuchet's performance.
Crouch
For a physichs project I had to build a trebuchet. I measured how for it shot, and how long it took. After some calculations I got:
Vi in the X= 6.258
VI in the y= 6.64
Accel in X= 0
Accel in Y= -9.8
Distance in the X= 4.8
Distance in the Y= 2.25
Time in the X= 1.36
Time In the Y= .68
Now after that I am supposed to pick different points on the arc and measure the Velocity in the Y and X. I am not sure what distance to use? For instance if I wanted to measure the velocity at .1 seconds in the arc on the X and Y, what would I use?
Someone Please Help Me. I can only stay online another 40 minutes, and I need this done tonight.
The velocity versus time relationships are:
v_{x} = v_{0}\cos\alpha
v_{y} = v_{0}\sin\alpha - gt
In your case.
v_{i,x} = v_{0}\cos\alpha
v_{i,y} = v_{0}\sin\alpha
velocity at any point = vi+at
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
