Measuring Capacitance given a voltmeter + ammeter
4 replies · 7K views
mikel2009
Given the following:
• a battery,
• a digital voltmeter (which records voltage as a function of time),
• a digital ammeter (which records current as a function of time),
• a battered industrial capacitor,
• two copper plates,
• and several bits of copper wire.
measure the capacitance of the industrial
capacitor
(there's a second segment of the question, but i understand it)
C=Q/V. etc.
I=dQ/dt.
I have attempted to write a solution to this, but am only confusing myself.
The voltage is a given, however I'm uncertain how I'm supposed to obtain Q from the dQ/dt graph, in order to determine capacitance.
someone please shed some light -.-
This is just an assumption that I thought: Hope it helps
The ammeter is recording current as a function of time, so the reading is actually I/t.
From here we can calculate Q.
Q = I from ammeter readings . t
the I is the reading from the ammeter, so it becomes Q = I/t . t
the t cancel out so Q = I
Does it makes sense?
the usual way to measure the capacitance works with an ac voltage source!
Your way is to vague!
Have you had integrals in calculus class?
Well, not really. The ammeter reading is I, period.
It's not "his way", it's the way given in the problem statement and he is stuck with it. :smile:
You answered this yourself with the provided equations.
Differentiate C = Q/V
Bearing in mind that I = dQ/dt as well as the nature of a capacitance of a capacitor
Then look at what you are provided and it's very simple. Note the function of time parts of the question.
P.S. aren't you leaving this a bit late ;)
