Mechanical calculator design problems
The discussion revolves around the design challenges of a mechanical calculator, specifically focusing on determining the dimensions of gears such as thickness and diameter. The designer seeks guidance on whether to select convenient sizes or conduct specific analyses for optimal gear dimensions. Suggestions include referencing existing mechanical devices like natural gas flow meters and car odometers for inspiration. Additionally, there is mention of the historical context of mechanical calculators, with examples of older models like the Friden and Marchant. Overall, the conversation emphasizes the need for careful consideration in gear design to ensure functionality.
kevjcarvalho
hey...i have designed a mechanical calculator...i am using spur gears, bevel gears and stepped drums(Leibnitz drum)...my design is ready but the problems is how do i decide the dimensions of the gears like thickness, diameter etc...do i just select a convenient size...or do i do some analysis...if yes what analysis?...all my components will be made from nylon...custom made...please help...i have attached different views of the model with the frame removed...
Why? Natural gas flow meters and car odometers both have rotating dial mechanical readout with decimal carry. Copy them. About 40 years ago I sold my mechanical Friden desk calculator with multiply and divide for $25. I suspect you can still find them (or Marchants) in 2nd hand stores.
Bob S
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
