Verify Answers to Mechanical Energy Homework
The homework problem involves calculating the mass of a child on a swing and their speed at the bottom of the arc after being pulled back. The height difference of the swing is determined to be 0.267 m, leading to the calculation of mass using the equation mgh = 100 J, resulting in a mass of 38.21 kg. To find the speed at the bottom of the arc, the equation mgh = 1/2 mv^2 is used, which simplifies to yield a speed of 2.287 m/s after canceling the mass. The calculations presented are verified as correct.
goonking
You do 100 J of work while pulling a child back on a swing, whose chain is 2.0 m long, until the swing makes an angle of 30.0° with the vertical. a) What is the child's mass? (Consider the swing itself and the chain massless) b) Upon releasing the swing from this position, what will the speed of the child be at the bottom of the arc?
mgh = 1/2 mv^2
After doing some trig, I get the height difference of the swing to be 0.267m; we now have h in mgh.
since he exerted 100 Js, we set mgh = 100, solving for m
m = 38.21 kg
now we want to find the speed at the bottom of the arc.
we set mgh = 1/2 mv^2
Mass cancels out
we solve for V, which should be 2.287 m/s.
Can someone verify if my answers are correct?
Likes Suraj M
Your work looks good to me.
Likes billy_joule
