Mechanical Failure of a Truncated Cone
To calculate the failure point of a truncated cone under uniaxial stress, key data needed includes the material properties, such as yield strength and tensile strength, as well as geometric dimensions like height and base radius. The applied stress must be converted into appropriate units, such as pounds per square inch or kilopascals, to ensure accurate calculations. Understanding the load distribution and potential stress concentrations is also crucial. The discussion emphasizes the importance of material selection, particularly since the cone is likely made of plastic, which has different failure characteristics compared to metals. Accurate calculations will help determine the cone's structural integrity under a downward force of approximately 30 tonnes.
DougieB39
What data do you need to calculate the failure point of a truncated cone when it is under uniaxial stress acting downward on the cone? The cone will be under stresses of roughly 30 tonnes and probably constructed of plastic.
Thanks,
What are you trying to do? Stress is in units of lbs/in^2, kPa, etc. 30 tonnes is a force.
Thanks
Matt
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
