Automotive Mechanical vs. electric coolant pumps
Electric coolant pumps are increasingly being used in production vehicles, particularly in hybrid and electric models, with Audi and Toyota Prius as notable examples. Many manufacturers are transitioning to electric pumps to reduce parasitic drag and improve fuel efficiency. There is a growing market for aftermarket electric pumps designed to replace mechanical ones in high-performance vehicles. The discussion highlights a need for more information on the control mechanisms for these pumps, particularly regarding the integration of thermostats and flow rate management. Overall, the trend indicates a shift towards electric auxiliary components in the automotive industry.
Zirkus
Hi everyone, I am conducting a small research on how many manufacturers (if any) use electric water pumps in production vehicles. So far I found that many Audi models have auxiliary electric pumps which help the main mechanical one when needed (and maybe to run for some minute after turning the engine off) and also that the Toyota Prius runs an electric pump. Apart from that i found many companies selling electric pumps to replace mechanical ones in high performance vehicles (Meziere, CSR atc.). Do you know about any production vehicle relying solely on an electric pump? I would also be interested in how the control is designed, namely if you still need a thermostat (I think yes) and how it would be adjusted so as not to conflict with controlling the pump flow rate. Thanks for any answers/tips/links!
Can't tell you how many are currently using it, and I'm not inclined to look. You can already see electric and hybrids using them, as they have the battery capacity to do so (so it's a logical step). I'm fairly sure that new efficient dynamics BMWs are running electric power steering and coolant pumps.
But in the effort to reduce parasitic drag (for emissions/fuel consumption targets) all manufacturers will be moving almost all front end auxiliary components to electric drive.
http://papers.sae.org/2004-01-0596/
Thank you Chris, it does indeed seem to be a trend for the future. However I haven't yet found any description of how the automatic control is implemented (PWM presumably, but that doesn't say much). Any tips where and how to look please? Googling "vehicle with electric water pump" is not too effective I have found :p As for my motivation: I want to find an electric pump with flow at least 100 litres/min from a production car of which at least 2500 pieces were sold. It doesn't look like a too hard task, but I just can't figure out how to look. Thanks again...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
