Mechanics problem (Bullet penetration)
A 7.00g bullet penetrates a 1.00kg block of wood to a depth of 8.00cm when fired into a fixed block. When the block is placed on a frictionless surface, the bullet will penetrate a shorter distance due to the conservation of momentum during the collision. The equations derived show that the penetration depth can be calculated using the relationship between the masses and initial velocities. The final calculated penetration depth is approximately 7.994cm, indicating minimal difference from the first scenario. The discussion emphasizes the importance of momentum conservation in inelastic collisions.
tanzl
A 7.00g bullet, when ired from a gun into a 1.00kg block of wood held in a vise, penetrates the block to a depth of 8.00cm. This block of wood is placed on a frictionless horizontal surface, and a second 7.00g bullet is fired from the gun into the block. To what depth will the bullet penetrate the block in this case?
In the first case, by taking the final velocity as 0 and displacement as 8.00cm.
I can get the initial velocity of bullet in terms of acceleration or time by using kinematics equations.
or I can find the force of the bullet exerts on the block by equating EK = F\Deltar
But they are not seems to be useful in case 2.
In case 2, I am not sure how the mechanics will occur. But, I think the bullet will travel with the same initial velocity, penetrate a shorter distance into the block and bring the block to travel with it with some velocity. I do not know how to put this by using physical principals. I guess I need to use conservation of energy again. By equating
EK of bullet = F\Deltar + EK of (bullet + block). But I do not think I have enough information to do that. Please help me.
You're on the right track. Hint: What else is conserved during the collision of bullet and block in case 2?
I think momentum is conserved which gives
\frac{1}{2}mv1 = (M+m)v2 ...(1)
where m=mass of bullet
M=mass of block
v1=initial velocity of bullet
v2=velocity of bullet and block
From the 1st case,
I have \frac{1}{2}mv12 = F\Deltar1 ... (2)
From the 2nd case,
\frac{1}{2}mv12 = F\Deltar2 + \frac{1}{2}mv22... (3)
By equating (3) and (2)
I have F(\Deltar1-\Deltar2) = \frac{1}{2}(M+m)v22
But I still have one extra unknown (r2 , F , v1) for 2 equations.
I have one more question here, if I had assumed that the collision is inelastic, will (3) still correct since the kinetic energy is not conserved anymore.
M=mass of block
Good. But get rid of that 1/2.
From the 1st case,
Good.
From the 2nd case,
Good, but that second "m" should be "M + m".
You have 3 equations. In any case, noodle around with the equations, expressing everything in terms of F, r_1, & r_2. See what happens.
The collision is most definitely inelastic. KE is not conserved--total energy is conserved. (Your equation 3 is a total energy equation, not simply a KE equation.)
Oops... I apologise for all the typing errors.
Wow, the unknowns canceled like magic. Thank you so much.
The final answer I got is 7.994cm. Not much different from the first penetration.
I get a slightly different answer, so you might want to recheck your arithmetic. But there's not much difference.
I recheck my arithmetic. There is nothing wrong.
The final expression I get is
mv12 = mv12*\frac{\Delta r_2}{\Delta r_1} + \frac{m^2}{M+m}*v12
Canceled off all the v and m gives
\Deltar2 = \frac{M}{M+m}*\Deltar1
= 1/1.007 * 0.08
= 0.07994m
tanzl said:
Canceled off all the v gives
Right.
= 1/1.007 * 0.08
= 0.07994m
According to my calculator, 1/1.007 * 0.08 = 0.07944 m.
Yea.. Thank you so much for your help.
