Prototype 3-Wheeled Car Steering Mechanism
In summary: My idea requires the programming of one motor either clockwise or counter clockwise.It also allows for mechanical advantage so you can use a smaller motor. With ank's concept you cannot change the diameter of the drive shaft or the driven and so if you motor is not strong enough you need a new motor instead of a larger sprocket.Why not just put the two wheels up frontand use one in the...back?
Moneim230
hello all
i'm creating a prototype for a 3 wheeled car ( 2 wheels at the back & 1 wheel in the front ) motor with the 2 wheels in the back
i want to test its stability so i want it to move in a straight line then take a curve
can someone suggest a simple mechanism for the steering (from the single wheel in the front) ?
If you only have a single drive(single drive to both wheels), you need to tilt the axis of the front wheel, like a bike.
If you have separate drives for both rear wheels, just use a castor at front, and control the speed of both motors for steering.
for the first suggestion : will i need to do it manually ? is there any mechanism that can make it move in a straight line then take a curve (tilt the axis) ??
thanks for help ^_^
Actually it would be quite easy to do. I'm assuming you have access to motors. a small motor with a sprocket on the drive shaft and a chain attached to a sprocket on the wheels shaft and you could have it steer either direction you wanted. (this requires some programming if you want to control steering)
The other option is to rig it with a string to a fixed point, when the string goes taught itll jerk the wheel in one direction. but then it'll go in a circle around this fixed po9int until you shut it off or you run out of string!
What else??
you cane make a link attached to the shaft of the front wheel, now pull it back to steer one way, push it to steer the other way.
I didn't get you clearly bear, won't it make it a one way process??
Anyways, 230, one more idea, mount your front wheel on a shaft, and tie a string to its both ends(wheel is in the middle), now pull this string from one side to steer, & pull from the other side to steer other. Pretty stupid, huh?? You need two exactly same motors(small ones) with each string wrapping over each shaft. Rotate the motors in opposite directions, so while you pull one side, other side will be unwrapping & vice versa.
Actually, this is how B737 steers, with hydraulic actuators in place of strings.
To Ank
Well the second way would, but if he is just testing stability in the process of turning, it would work. The first way is similar to your B737 idea but it only requires the programing and control of one motor. They use hydrolics on planes because you can get more force and they use a hydrolic system to control the flight elements. It would be simpler and more efficent to use one motor with a chain and sprockets.
I suggested the rope and fixed point because i wasn't aware of any programming skills or circuitry skills which will be required if he is going to want to control the motor apart from on and off. If 230 could let us know of his capabilities and budget we could give more suitable ideas.
i think the idea of 2 motors at the back is better & easy so i'll use it
Oh yes, right bear, using a sprocket makes it equivalent to a link.
Is this for some robotics contest?? If yes, differential drive is your best bet, while for bigger systems, this type of steering is a wastage of energy.
Best of luck.
Actually it reuires much more complex programing then using a single motor and chain.
For that style you have to program the motors to run in opposite and be synchronized.
It will require programming for two motors. Since it has two motors it is also more expensive.
why not just put the two wheels up front
and use one in the back
if you must have three wheels
like the old morgan trikes
1. How does the 3-wheeled car steering mechanism work?
The 3-wheeled car steering mechanism uses a combination of mechanical components, such as a steering column, steering rack, and tie rods, to transfer the driver's input from the steering wheel to the front wheels. This allows the driver to turn the wheels and change the direction of the car.
2. What are the benefits of a 3-wheeled car steering mechanism?
A 3-wheeled car steering mechanism offers improved maneuverability and a tighter turning radius compared to traditional 4-wheeled steering systems. It also allows for a lighter and more compact design, making it suitable for smaller vehicles or those with limited space.
3. Is the 3-wheeled car steering mechanism safe?
Yes, the 3-wheeled car steering mechanism is designed with safety in mind. It undergoes rigorous testing and meets all safety standards to ensure the driver's control and stability of the vehicle.
4. Can the 3-wheeled car steering mechanism be used in all types of vehicles?
While the 3-wheeled car steering mechanism is commonly used in smaller vehicles, it can also be adapted for use in larger vehicles such as trucks and buses. However, it may not be suitable for high-speed or heavy-duty vehicles.
5. How does the 3-wheeled car steering mechanism compare to other steering systems?
The 3-wheeled car steering mechanism offers unique advantages over other steering systems, such as improved maneuverability and space efficiency. However, it may not be as stable at high speeds compared to traditional 4-wheeled steering systems. The best steering system for a vehicle depends on its intended use and design.
  • Mechanical Engineering
  • DIY Projects
