Medium level calculation of center of mass
The discussion revolves around calculating the center of mass using integration methods for different shapes. For part (a), the user employs linear density to find the mass of a circumference and seeks confirmation on the approach. In part (b), surface density is used to calculate the mass of a disk, with a suggestion that this is correct if referring to a hemispherical shell. The conversation also touches on the choice of coordinate systems, noting that while spherical coordinates are easier, Cartesian coordinates can also be used effectively with the right trigonometric substitutions. Overall, the focus is on verifying integration methods and coordinate system choices for the calculations.
eileen6a
integration
for a) i use linear density and calculate the mass of circumference and integrate it bottom to top. is it riight?any other methods?
for b) i use surface density and calcuate the mass of disk and intergrate bottom to top is it right?any other methods?
also do i need to use spherical coordinate? is it exceedinly difficult to use cartisian?
hi eileen! :smile:
erm :redface:where did the question go? :confused:
why disappear? the file as attached thx~
hi eileen! :smile:
(wouldn't it have been quicker just to type the question? :confused:)
correct in principle, but difficult to say whether you're actually doing it right without seeing the calculation :wink:
if by "disk" you mean "hemispherical shell", yes
and there's no other method that uses (a)
spherical is easier, but Cartesian will also work, so long as you know your trig substitutions for the integral :smile:
