Millenium falcon firing a laser
  • Thread starter Thread starter nick227
    Laser
nick227
you are on the millenium falcon, going at the speed of light, and you fire a laser. does the laser go anywhere?
if you were on a truck moving at 50m/s and threw a ball forward at 20m/s, then the ball would go at 70m/s. not the same when dealing with c, right?
so then how can the laser go anywhere?
Special Relativity has two postulates:
1. The laws of physics are the same in all inertial frames of reference.
2. The speed of light is constant in all inertial frames of reference.
That means, if you are in a truck moving at 50m/s and throw a ball forward at 20m/s, the resulting speed of the ball is not 70 m/s and when a spacecraft fires a laser, it travels away from the spacecraft at the speed of light, regardless of the speed of the spacecraft . If you are moving much slower than the speed of light, these effects are not noticeable, but they are still there.
u=50, v=20. The ball's velocity relative to the ground: u+v=70.
One thing that special relativity tells us is that this way of adding velocities is only approximately correct. This is the right way to do it, according to SR:
\frac{u+v}{1+uv/c^2}
When the velocities are small compared to the speed of light, the naive way to add velocities works extremely well, as you can verify yourself.
Millennium Falcon: u=0.99c (relative to "planet X")
Laser: v=c (relative to the MF)
The laser beam's speed relative to planet X:
\frac{u+v}{1+uv/c^2}=\frac{0.99c+1c}{1+0.99\cdot 1}=c
Of course it does! Otherwise the reviews of the movie would be terrible. And besides, who would pay George Lucas to make special effects that can't be seen.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
