What is the minimum force needed to move a block with friction present?
The discussion centers on determining the minimum force required to move a block in the presence of friction, with participants debating the correct formula. Initial claims suggest that the minimum force is given by F > μF_N, but confusion arises regarding the normal force (F_N) and whether the applied force can be at an angle. It is clarified that applying force at an angle reduces the normal force, thereby decreasing friction and allowing for a lower required force. Participants emphasize the importance of understanding the relationship between force, angle, and friction in solving the problem effectively. The conversation highlights the need for clear problem statements to avoid misinterpretation.
rudransh verma
A body of mass m results on horizontal floor with which it has coefficient of static friction ##\mu##. It is desired to move the block with minimum possible force. Find the applied force F.
##F_n=ma##
##F_s=\mu F_N##
We know the minimum force to move the body in presence of friction will be ##F>\mu F_N##
But it’s not right.
But it’s not right.
Why not? (What does ##F_N## equal?)
Where is the effort here?
  • Haha
Likes Tesla In Person
I am intrigued, what is the answer key @rudransh verma . Why you say its not correct? According to my opinion the minimum force is ##\mu mg##.
  • Skeptical
Likes jbriggs444
Yes ##\mu mg##. But the answer in my book says ##F=\frac{\mu mg}{\sqrt{1+\mu^2}}##
Something is fishy here, can you post some sort of figure that perhaps exists in the book for this problem?
Did you provide the complete problem statement?
Likes rudransh verma
Seriously? You only now thought it relevant to tell us that the applied force F is at an angle?
  • Love
Likes Steve4Physics, Delta2, berkeman and 1 other person
No. This is the complete question. There is no mentioning of any angle as you can see.I don’t know why they are applying force at an angle.
So you are saying that the diagram you just posted has nothing to do with this problem?
Likes Vanadium 50
I am saying they have solved the problem assuming force at an angle. That diagram is not the part of question but of the answer.
That's a bit hard to believe.
(1) Post the complete problem statement
(2) Post the complete solution provided.
  • Love
Likes Vanadium 50, Mark44 and russ_watters
Ah, I see the issue now. You were not told anything about the direction of the applied force, so you are free to apply it in any direction to solve for the minimum force needed. Assuming that the applied force must be horizontal was a mistake.
Likes vcsharp2003
See my last post. Do you see how being allowed to apply the force at an angle can affect the answer?
Because that lowers the normal force and therefore the horizontal force required to move the block. Since the problem did not say anything about the direction, in order to find the minimal force, you need to find an expression for the required force as a function of the angle and then minimise with respect to the angle.
Likes Vanadium 50 and Delta2
Is this more readable?
Likes Delta2
OK , well I am not sure if that "the force applied must be at an angle " should be part of the problem statement or the student would have to think it. I was not smart enough to think it, and I am deeply sorry for myself o:).
  • Haha
Likes vcsharp2003 and sysprog
Everybody makes bloopers or misread problems sometimes. Obviously, stating explicitly that the force could be at an angle would make it more obvious, but technically it is also fair game with the problem just stating to find the minimal force.
Likes Delta2, vcsharp2003, Doc Al and 1 other person
The problem asks specifically for the magnitude of the force. That's a very broad hint here.
Likes vcsharp2003 and vela
It can help to put yourself into the problem. If you had to tug a heavy mass across a floor, how would you do it?
Likes Nugatory
I don't know how you think but according to my thinking and intuition I would push it with horizontal force.
Likes Tom.G and russ_watters
So you just learned something practically useful! 😉
In addition, pulling at an angle will also mean helping to overcome issues of bad grip on the ground on your part as you also increase your own normal force.
Likes russ_watters and jbriggs444
Maybe you need to do more manual labour!
Two physicists were watching workmen on a building site. "See how he pulls the wheelbarrow behind himself instead of pushing it in front. He has obviously worked out that because he is pulling up at a slight angle it reduces the rolling resistance", observed one.
The other physicist asked the workman why he did it. "I've pushed wheelbarrows for thirty years," he replied, "and I'm fed up with the sight of 'em."
  • Haha
Likes phinds, Nugatory, russ_watters and 6 others
To apply minimum force the force of friction has to be less and will become less when we decrease the normal force and that would mean a tilted block.
But the eqns are ##F_N+F\sin \theta =mg##
##F\cos \theta=\mu F_N## which I don’t think is consistent with the tilted block.
No, it would not necessarily tilt the block. Why do you think so? There is a separate set of equations (based on torque balance) that would tell you whether the block tilts or not.
Why not? They are valid as long as the coefficient of friction remains the same.
If it will not leave the ground at least from one side how the friction will decrease ?
By decreasing the normal force. Maximal friction is proportional to normal force.
Likes russ_watters
Are you saying applying a force at an angle can decrease the friction without actually lifting it. That there is some ##0<F_N<mg##
  • #31
You should be able to figure out the answer to this. What does force and torque balance on the block tell you? For simplicity, consider a homogeneous block with mass ##m## with a vertical string being pulled up attached to one of its sides. Will the block start tilting at the first minimal application of force? If not, how hard can you pull before it does?
  • #32
No. I think if we apply some upward force block will not move because ##F_N+ F_a=mg##. We need to increase the ##F_a=mg##. Then block will move. So we can apply a force to decrease the normal without actually lifting it up.
##F_a## is applied force.
  • Skeptical
Likes jbriggs444
  • #33
Not be lifted up, when does it start tilting? Did you draw a free body diagram and do the torque analysis?
  • #34
I have not studied about torque. Sorry. It’s in future chapters.
But I get it. Force at an angle will have its component in the direction of normal and that will decrease the normal force and thus friction. It will be enough to move the block forward.
Likes Delta2 and berkeman
  • #35
That is fine. Just as long as you are aware that until you reach and have learned those chapters, you will not really be able to tell when things tip over etc.
  • #36
Now that OP has announced that he "gets it", I think it is time for me to note that this question is not very well designed. Presumably it tests the extent to which the solver has mastered static friction and FBDs. However, its presentation as a multiple choice question leaves something to be desired because the entire process of finding the minimum force through an FBD, an understanding of ##f_s^{\text{max}}## and optimization, can be bypassed by a "solver" who knows nothing about these subjects but can interpret mathematical equations.
When ##\mu>1##, the first 3 choices are clearly greater than the weight ##mg##. In that case, one can "make the body move" by pulling straight up with a force that is equal to the weight and less than any of the first 3 choices. Thus, none of these can be a minimum. This leaves the fourth choice as the answer.
Likes Dadface, Delta2 and Doc Al
  • #37
Depending on the block dimensions, it might not be possible to move the block with minimum force so applied without its tilting.
Just as we are free to choose the angle of the force, we can choose where to a
apply it. By exerting it along a line passing through the point at floor level directly below the mass centre we can avert any risk of tilting.
Not that tilting is necessarily a disadvantage. If it turns out that it can allow a yet lower force magnitude then the problem is not well posed.
Specifying a rectangular block of given dimensions and a string attached to the base (say) at one end could be the basis of a more advanced question.
  • #39
If we think about it when we rather apply force at an angle we do decrease the force of friction but we now are applying some force against gravity. So are we really minimising any applied force?
Is friction playing bigger role than gravity?
  • #40
The entire point of this problem is to figure this out and to figure out which angle of application gives you the minimal force requirement.
  • #41
Right! So we make some eqns and find ##dF/d\theta## ie rate of change of force with respect to angle change and then take the derivative equal to zero to get the minima/maxima force.
So, ##dF/d\theta=0##, ##\mu =\tan \theta##
But how do you decide if its maxima or minima force at ##\mu =\tan \theta##?
  • #42
Do not just show your answers. Show your work. That would make it easier to suggest the second derivative test.
Likes Vanadium 50
  • #43
$$F\sin \theta +F_N-mg=0$$
$$F\cos \theta- \mu mg=0$$
So,$$F=\frac{\mu mg}{\cos \theta+\mu \sin \theta}$$
Finding max/min force, $$dF/d\theta=0$$
After solving,
$$\mu=\tan \theta$$
Likes Delta2
  • #44
After solving,
$$\mu=\tan \theta$$
You have not shown your work taking the derivative of F and solving for the zero(es) of the resulting function.
Likes Vanadium 50
  • #45
$$dF/d\theta=d/d\theta(\frac{\mu mg}{\cos \theta+\mu \sin \theta})$$
$$=-\frac{\mu mg}{(\cos \theta+\mu \sin \theta)^2}d/d\theta (\cos \theta+\mu \sin \theta)$$
$$=-\frac{\mu mg}{(\cos \theta+\mu \sin \theta)^2}(-\sin \theta+\mu \cos \theta)=0$$
$$=\mu mg\sin \theta-\mu ^2 mg\cos \theta=0$$
$$=\sin \theta-\mu \cos \theta=0$$
$$\mu=\tan \theta$$
  • #46
After solving,
$$\mu=\tan \theta$$
Your second equation seems to have assumed that the frictional force is ##\mu mg##, but this is no longer the case if the normal force is not ##mg##. It would imply ##F = \mu mg/\sin\theta##, but this is not what you obtain. Please show your intermediate steps.
  • #47
Orodruin said:
Your second equation seems to have assumed that the frictional force is μmg, but this is no longer the case if the normal force is not mg. It would imply F=μmg/sin⁡θ, but this is not what you obtain. Please show your intermediate steps.
Sorry, I did a blunder. Second eqn should be ##F\cos \theta-\mu F_N=0##. This should produce the correct eqn.
  • #48
In order to find whether it is a max or a min you need to take the second derivative of ##F## and find if it is positive or negative for the value of ##\theta## that you found. However, since the dependence on ##\theta## is in the denominator, it is probably easier to consider ##f = 1/F## instead. Since ##1/x## is a monotonously decreasing function (for ##x > 0##), ##f## and ##F## will share their extreme points. Where ##F## has a max, ##f## has a min and vice versa.
Likes jbriggs444
  • #49
First I started taking the usual case ##d^2F/d\theta^2=-mg\sin \theta(\cos^2 \theta(3\cos ^2 \theta-2)-\sin^2\theta(1+cos^2 \theta))##.
But its difficult to tell its -ve or +ve.
So as you said ##df/d\theta=(1/\mu mg)(-\sin \theta+\mu \cos \theta)##
and second derivative is ##-1/mg\sin \theta## after taking ##\mu =\tan \theta##
So its -ve. That means what?
Can you explain the maths in more detail here?
  • #50
Yes, that quickly becomes messy, which is why I suggested checking whether the denominator had a minimum or maximum since the numerator is constant. Those are tricks that one picks up with experience. Now the reason it works is the following, consider two (non-zero) functions ##F(x)## and ##f(x) = 1/F(x)##. We then have (##x## being some arbitrary variable the functions depend on)
f' = \frac{df}{dx} = \frac{d(1/F)}{dx} = -\frac {F'}{F^2}
and so ##f'(x_0) = 0## if ##F'(x_0) = 0##. It then also follows that
f'' = -\frac{d}{dx}\frac{F'}{F^2} = - \frac{F''}{F^2} + 2\frac{F'^2}{F^3}.
If we evaluate this for the extreme point ##x_0##, then ##F'(x_0) = 0## and therefore
f''(x_0) = -\frac{F''(x_0)}{F(x_0)^2}.
Hence, ##f''(x_0)## is positive if ##F''(x_0)## is negative and vice versa. So if ##x_0## is a max of ##f##, it is a min of ##F##, etc.
Likes Delta2
