Minimum speed on banking road (circular motion)
The discussion revolves around calculating the minimum speed required for a car to navigate a slippery banked curve without slipping. The user initially derived an equation for minimum speed but found it did not match any answer choices. Participants pointed out the need to consider forces in both the x and y directions, particularly the role of friction, which can act upwards or downwards depending on the car's speed. The importance of including the frictional force's y-component in the equations was emphasized for accurate calculations. The user acknowledged this oversight and was guided towards correcting their approach to find the correct answer.
Elbobo
A car rounds a slippery curve. The radius of
curvature of the road is R, the banking angle
with respect to the horizontal is θ and the
coefficient of friction is μ.
What is the minimum speed required in order
for the car not to slip?
Fc = (mv^2) / r
W = mg
Ffr = μ N
So I made the xy-plane standard, weight in the negative y-direction.
x-direction:
Nx + Ffr(x) = Fc
N = (mg) / cos (th)
Ffr(x) = (μmg) cos (th) / cos (th)
= μ mg
Nx = [ (mg) sin (th) ] / cos (th)
Nx + Ffr(x) = Fc
μmg + (mg sin (th))/cos (th) = (mv^2) / r
v(min) = sqrt [ gr (μ + tan (th))]
That was my answer, but it's not an answer choice. I don't know where my thought process was wrong. Can someone help?
It is good to clearly define an axis. In the next step, you have equated the forces along the x direction. What you should do next is to equate forces along the y direction, no?
In other words, can you check again if this equation is correct?
N = (mg) / cos (th)
Finally, you should think about what direction the friction force acts. If the car is going sloooowly, which direction (upwards or downwards) will it tend to slide?
Yeah, but I don't see why it's not correct. I don't understand what other horizontal forces are acting. I thought the net force is always the centripetal force. Weight is perpendicular to the horizontal forces, so its component would be zero...
EDIT: oh right, so friction would act upwards? Didn't realize it would change depending on speed...
Your equation for the horizontal forces is perfect. I'm concerned about the equation relating N to mg.
Yes, friction opposes the direction of motion (or the direction in which the body is trying to move). If you move too fast, you can imagine that the friction acts downwards. In fact, this will mean that at some velocity, there will be no friction.
OH! I assumed the net force in the y direction equals zero.
N cos (th) - mg = 0
so N = mg / cos (th)
Yet I should've included friction's y component, right?
Yes, good job figuring this out. You should be able to work out the answer from here.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
