Minimum Thickness of Dielectric
The discussion focuses on determining the minimum thickness of dielectric and its permittivity required to keep the electric field in a coaxial cable below its maximum value. The electric field is defined by the equation E = (Q/L)*(1/2*pi*e*p), where p is the cylindrical distance between the wires. To ensure the electric field remains below its maximum, the dielectric must be applied, which modifies the electric field strength. The maximum field occurs at p = (a+b)/2, and the dielectric's thickness t will influence the field reduction by a factor of 1/ε. The calculations involve using Gauss' law to derive the necessary parameters for the dielectric coating.
iblackford
1. Basically, we have coaxial cable with an inner wire of radius a,
perfectly conducting, straight and infinitely long, with radius a, surrounded by an outer hollow cylinder, also made
from perfectly conducting material, having inner radius b and outer radius c. The hollow cylinder functions as a
return wire, and is coaxial with the inner wire. If the space between the wires is air or vacuum, the electric field
between the inner and return wires is shown to be
where Q/L is the charge per unit length and  the cylindrical distance between the wires.
Suppose the ~E field cannot be allowed to reach values above the value it reaches in the middle of the arrangement,
where p = (a+b)/2
2 . This can be achieved by shielding the inner cable with a dielectric of permittivity e.
a) What is the minimum value of e and the minimum thickness of dielectric coating that will ensure that the field
is everywhere below its maximal value?
b) What is the capacitance per unit length of the resulting arrangement.
I'm not sure how to do the first part of the problem, I think I would sub in my p = a+b/2 into my first equation, but I'm not sure what to do from there. Any help would be highly appreciated.
where Q/L is the charge per unit length and p the cylindrical distance between the wires.
Just use Gauss' law for a Gaussian cylinder of radius p:
\int E\cdot dA = \frac{q}{\epsilon_0}
where p = (a+b)/2
The maximum field is the E determined in 1 where p = (a+b)/2. A dielectric of thickness t will reduce this by a factor \frac{1}{\epsilon}
from p=a to p = a+t. So work out the expression for E at p=a+t. The value of E from p=a+t decreases as 1/p.
AM
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
