Minkowski Diagram for Twin Paradox
In summary, the Minkowski diagram in the frame of A would show B's world line as a straight line making an angle of less than 45 degrees with the positive ct axis, and the return journey would be drawn as a reflection of this line in the ct axis. In the frame of B, the diagram would be a reflection of the above in the ct axis with the axes relabeled as x' and ct'. However, it is not possible to draw both journeys on the same diagram using different frames.
latentcorpse
1,444
In the twin paradox, if B moves away from A at constant high speed what would the minkwoski diagram look like in the frame of A and in the frame of B.
well in the frame of A. if B starts next to A i.e. at O and is moving at close to c to begin with the world line of B will just be a straight line making an angle of just less than 45 degrees with the positive ct axis, yes?
but how do i draw the return journey?
and in the frame of B the diagram should end up as just a reflection of the above in the ct axis (and i also have to relabel my axes to x' and ct'), yes?
cheers.
Hi latentcorpse! :smile:
You're not asked to draw the return journey …
but if you did, wouldn't it be the same slope, but down instead of up ? :wink:
And how could you draw the return journey "in B's frame", when he has two frames?
Yes … if they're using their common x-axis, then B uses -x where A uses x. :smile:
so in the frame of A if x is horizontal axis and ct is vertical axis it would look like
hopefully that makes sense i.e. he returns back to his x=0 position with teh same velocity
i don't understand what you mean by "B has two frames"
also i just made this question up so its not very rigorously worded haha
ah :redface: … i should have guessed! :biggrin:
hopefully that makes sense i.e. he returns back to his x=0 position with the same velocity
(use the CODE tag:
Code:
:wink:)
Yes (though I'd prefer t along the bottom axis :wink:).
I mean you can't do the same thing for B, because he has a different velocity, and therefore a different frame, on the way out, as he does on the way back. :smile:
interesting. hadn't even thought of that. so on his way out, A has a world line making just less than -45 degrees with the positive ct axis.
than i was thinking about jumping over to the positive quadrant (i.e. a discontinuity at the point where he turns round)? not sure though
Noooo … in Special Relativity, you need to keep the same frame. :smile:
but you said B has a different fram on the way back - doesn;t this contradict special relativity itself?
shall i draw this on two separate minkowski space time diagrams then?
oh and why do we need the same frame?
No … why should it? :confused:
If it makes you happy …
but I don't see what good it will do you.
How can you combine results for, say, x' t' and x'' t'' if you use different frames?
You'd never dream of using two different frames for a single calculation in any other branch of maths or physics :wink:
ok. I am getting confused!
2 main problems:
(i)"I mean you can't do the same thing for B, because he has a different velocity, and therefore a different frame, on the way out, as he does on the way back."
"Noooo … in Special Relativity, you need to keep the same frame"
so in the first quote your saying i should use different frames and in the second one i shouldn't.
(ii) we'd relate them by a lorentz transformation - do you mean to transform the world line for B's return journey in his new frame back into the original frame using a lorentz transformation so i can plot them both on the same diagram?
ah … no, it's more that I'm saying that you would need two frames, but of course you can't.
uhh? :confused: when did I say that?
you can't plot them both on the same diagram
as I said …
… x' t' and x'' t'' if you use different frames?
so the only way to do this would be to use two separate diagrams - one for the outgoing journey and one for the retuen and as you said, this would not be very useful.
1. What is a Minkowski Diagram?
A Minkowski Diagram is a graphical representation of the spacetime coordinates and intervals between events in special relativity. It is used to visualize the effects of time dilation, length contraction, and the relativity of simultaneity.
2. How does the Minkowski Diagram explain the Twin Paradox?
The Minkowski Diagram can be used to visualize the journey of the twins in the Twin Paradox. The diagram shows that the twin who travels at high speeds experiences time dilation, meaning they age slower than the twin who stays on Earth. This explains why when they are reunited, the twin who traveled is younger than the one who stayed on Earth.
3. Can the Minkowski Diagram be used to solve the Twin Paradox?
While the Minkowski Diagram can help understand the concept of the Twin Paradox, it does not provide a solution. The paradox arises from the fact that both twins can consider themselves to be at rest and the other twin to be moving, therefore neither twin experiences time dilation. The resolution lies in the fact that one twin must accelerate and change direction, which breaks the symmetry and leads to a different experience of time.
4. Is the Minkowski Diagram only applicable to the Twin Paradox?
No, the Minkowski Diagram is a tool used in special relativity to visualize the effects of time and space in all situations, not just the Twin Paradox. It is commonly used in calculations and explanations of other phenomena such as length contraction and the relativity of simultaneity.
5. What are the limitations of the Minkowski Diagram?
The Minkowski Diagram is a simplified representation of the complex concepts of special relativity. It does not show the full 4-dimensional spacetime, and therefore cannot accurately depict certain scenarios, such as those involving acceleration and curved spacetime. It is also limited by the fact that it is a 2-dimensional representation, while spacetime is 4-dimensional.
