What Topics are Covered in Mixed-Signal IC Design Courses?
Mixed-signal IC design courses typically cover topics such as Verilog, amplifier design, and the integration of analog and digital components. These courses are relevant to industries focused on designing mixed-signal integrated circuits, which employ a significant workforce. If a student has not enjoyed digital design, it may be advisable to consider other areas, as mixed-signal design often requires a solid understanding of digital concepts. Additionally, analog design is noted to be more challenging than digital design. Overall, the course offers valuable skills for those interested in the mixed-signal IC field.
user101
Hi all - quick question: what type of topics do you learn in Mixed-signal IC Design courses? (at the upper undergrad level/low-level masters)?
I have a course entitled "RECONFIGURABLE MIXED-SIGNAL IC DESIGN" and was considering taking it in place of another course. I've read the wiki link, but was hoping someone else could expand on it further.
Generally you learn some Verilog and some basics of amplifier design.
-Warren
What field would this be most relevant to?
Also, if I didn't really enjoy my Digital Systems Design (used VHDL in it) that much, should I stay away from this class?
It would be most relevant to the industry (employing tens of thousands of people) who design mixed-signal integrated circuits.
If you don't like digital design, I'd probably look into something else, yes. You might like analog design, but I personally feel it's much more difficult than digital.
- Warren
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
