Mixing Problem (variable volume)
  • Thread starter Thread starter Tyst
    Mixing Volume
The discussion revolves around solving a first-order linear ordinary differential equation (ODE) related to a mixing problem in a tank. The tank initially contains 150L of water with 30g of salt, and brine enters at 4 L/m containing 1.5g of salt per liter while exiting at 3 L/m. The solution involves using the general formula for first-order linear ODEs, leading to the equation y(t) = e^(-3t)[∫(6/(150+t)e^(3t) dt) + C]. The user ultimately resolves their confusion regarding the integral and confirms their solution.
  • Understanding of first-order linear ordinary differential equations (ODEs)
  • Familiarity with integration techniques, particularly involving exponential functions
  • Knowledge of mixing problems in differential equations
  • Basic concepts of initial value problems in calculus
  • Study the method of integrating factors for solving linear ODEs
  • Learn advanced integration techniques, including integration by parts
  • Explore applications of differential equations in real-world mixing problems
  • Review the concept of initial value problems and their solutions in calculus
Students and professionals in mathematics, particularly those studying differential equations, as well as anyone involved in fluid dynamics or chemical engineering applications related to mixing processes.
Tyst
A tank contains 150L of water in which initially 30g or salt is dissolved. Brine runs in at a rate of 4 L/m and each litre contains 1.5g of dissolved salt. The mix in the tank is kept uniform. Brine runs out at 3L/m. What is that amount of salt in the tank at any time t?
Note that the volume of brime in the tank is not constant in time
y' +p(x)y = r(x)
General solution to first order, linear ODE
y(t) = exp(-\intp(p(t)) dt) [\int r(t)\exp(\intp(p(t))dt) dt +C]
Input/Output Gives
y(t)=(6-3y)/(150+t) <br />
y&#039;+3y = 6/(150+t)
Substituting these values into the general equation gives me
y(t) = e^(-3t)[\nt(6/(150+t)*e^(3t) dt) + C]
And from here ... well... some sort of a clue as to where to go next would be very nice.
Basically i am having trouble with that integral, is it possible to take \int(ln((6/(150+t)*\exp^(3t) dt) somehow? I'm not sure if/how to make this step.
I can take the log of the other parts of the equation...
ln(y(t)) = ln(exp^3t)+ [this is the bit I'm not sure of] + ln(C)
Yes, thanks for showing me that - perhaps it's just the tiredness setting in, or perhaps I'm just completely dense! But i am still not able to work this out.
Well, I'm an idiot :P solved it now! Thanks!
  • · Replies 27 ·
