MO Diagram of NO: Sigma vs Pi Bonding MOs
  • Thread starter Thread starter warenzeichen
    Diagram
In the discussion about the molecular orbital (MO) diagram of nitric oxide (NO), the focus is on whether electrons should fill the sigma molecular orbital (MO) or the pi MO first, considering their energy levels. It is noted that for diatomic oxygen (O2), the sigma bonding MO is lower in energy than the pi bonding MO due to the energy difference between the 2s and 2pz orbitals. The conversation highlights the complexity of determining the MO diagram for NO, which lies between nitrogen and oxygen. Participants suggest using freely available MO programs like YaeHMOP or GAMESS for calculations, emphasizing the educational value of hands-on experience. The discussion also touches on the variability of the energy levels of sigma and pi bonding MOs across different elements, indicating that the order can change depending on the specific atomic composition, particularly between lithium to nitrogen and oxygen to neon.
warenzeichen
I would like to know, in the MO diagram of NO should electrons put in the sigma MO first or pi MO first?
that means , which one has a lower energy level for the MOs.
For O2 , sigma was lower than pi bonding MO because of energy difference between 2s and 2pz, interaction say goodbye
There is a line between N and O... so what about NO ?
Thanks
Chemistry news on Phys.org
Why don't you just try to calculate it with any freely available MO Program e.g. YaeHMOP, gamess?
They aren't too difficult to use, run on any pc nowadays and you can learn a lot from it!
so, what can you guess or do when you attend an exam without pc?
The major things I would like to know is the "in between", either one must be the correct MO diagram, right?
sigma is always lower than pi (or do you mean sigma*?)
not sigma*, it's sigma
the relative position between sigma and pi bonding MO can vary from Li to N, and O to Ne
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
