Modeling an electron in a Magnetic Field
An electron in a magnetic field experiences a force defined by F = qV x B, leading to a trajectory radius of R = mv/qB. The discussion focuses on modeling the electron's path in 3D, particularly with initial conditions of Bx = 0, By = 0, and Bz = 1 micro tesla, with a velocity of Vy = 1.5e8 m/s. The calculated acceleration for ax is deemed excessively high at 4.23e13 m/s², prompting questions about the mass value used and the validity of the results. Suggestions include incorporating a time-dependent magnetic field and iteratively calculating the electron's position using updated velocity components. The conversation emphasizes the need for proper integration and consideration of forces acting on the system to accurately model the electron's trajectory.
Noone1982
I'm not sure where to place this, so please forgive me.
As you know, an electron experiences a force of F = qVxB in a magnetic field and equating this to centripetral force, we can find the radius of the electron's path to be R = mv/qB Ok, that's simple enough.
Now, I want to model an electron via 3D graphing in a magnetic field. For this, I need to model every part of its trajectory. This is proving tricky.
Say we have:
Bx = 0
By = 0
Bz = 1 micro tesla
The initial electron is coming in at
Vx = 0
Vy = 1.5e8 m/s
Vz = 0
The cross product is
Fx = q(VyBz - ByVz)
Fy = q(VxBz - VzBx)
Fz = q(VxBy - VyBx)
Now the acceleration is just a = F / m
However, For ax I'm getting 4.23e13 m/s^2! which is a wee bit high. Ok, just plain wrong. How would you generate an animation of an electon in a magnetic field? I would like to extend it so the magnetic field osccilates and varies with amplitude versus time.
Say we have:
Bx = 0
By = 0
Bz = 1 micro tesla
Vx = 0
Vy = 1.5e8 m/s
Vz = 0
Fx = q(VyBz - ByVz)
Fy = q(VxBz - VzBx)
Fz = q(VxBy - VyBx)
What is the mass value you used ? Besides, how do you know the value you got is too high ? What exactly did you do.
Anyhow, the approach and formula's are OK.
If you want to incorporate a t-dependent B field, you just need to integrate over time (once and twice) to get velocity and then the trajectory. How does the B field vary (sine, cosine) and along which direction (x,y,z) ? if you know this, just add the components into the right hand side of Fx, Fy and Fz. divide by m to get a and then you start the integrations...
marlon
I used the charge of an electron as 1.6022e-19 C and the mass as 9.1e-31 kg which is a charge to mass ratio of 1.76e11!
My plan was to do it iteratively. To calculate vx, vy, and vz and use rx = rx + vx*dt etc to plot the positions.
You are forgetting the t^2 term. There is a force acting on your system so you also need the a_x part in your equation for r_x !
marlon
