Modeling Jet Fans in Parking Ventilation in Ansys CFX
The discussion revolves around modeling jet fans for a parking ventilation system using Ansys CFX. The user has set up a fresh air inlet and exhaust outlet, and modeled jet fans as subdomains with momentum sources based on thrust calculations. They are also simulating a fire scenario with smoke using a flow inlet boundary condition. However, they are experiencing unrealistic results and seek feedback on their methodology and specific challenges related to numerically modeling the jet fans and smoke. The conversation highlights the importance of accurate modeling techniques and the need for detailed technical information from jet fan manufacturers.
tj00343
Hi , I'm new to CFD. I'm modeling a parking ventilation system in ansys CFX. I'm having some trouble modeling the jet fans . I went as follows. I created a fresh air inlet (Opening BC), an exhuast outlet (outlet BC) and in the middle I distributed jet fans .The jet fans are modeled as sub domains with momentum sources(momentum calculated from the thrust). In addition, I simulated a fire through flow inlet BC at a surface with and additional variable(smoke). I ran a transient analysis. The problem is the results seem unreal.
Generally, how does my methodology look. Am I on the right track. Any tips or ideas about why my results seem unreal.
Thank You
I've just looked at some jet fan manufacturers websites . In each case they give comprehensive technical information about their products .
The information provided seems to tell you everything you need to know .
Please describe what specific difficulties you have .
My specific difficulties have to do with how to numerically model the jet fans and smoke in ansys cfx
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
