Modelling of two phase flow in packed bed (continued)
427 replies · 36K views · last reply
casualguitar said:
One other note - the simulation running properly is dependent on the mass transfer coefficient (which is currently constant) being below a certain threshold. The current simulation uses a constant 8 x 10^-8 which is small enough, however the mass transfer coefficient calculator function does not return values in this range but rather in the 10^1 range. Is there anything wrong with this that you can see:
Where the following approximate ranges/values apply:
Reynolds number: 10<Re<10000
Schmidt Number: 0.5 < Sc < 0.7
Particle Diameter (dp) = 0.005
D CO2-N2 = 0.14 x 10^-4
D H2O-N2 = 0.259 x 10^-4
These values give a number in the 10^1 range, which causes the simulation to break, however the 10^-8 values produce expected results. Have I missed something?
How do the mass transfer coefficients compare with the values in the paper? Any value of the mass transfer coefficient should not cause the calculation to crash. What values of the heat transfer coefficient does the correlation give?
Chestermiller said:
Release the mass transfer coefficient correlation next.
Will do
Chestermiller said:
It's just what they gave in the other papers.
## U_b = \frac{k_p}{d_p/\beta}##?
Chestermiller said:
Did you mean "heat capacity correlation" or did you mean "heat transfer correlation?"
I meant heat capacity correlation but yes actually ##U_g## is constant in the current model also, so I'll need to add the heat transfer correlation in also. This seems more straightforward though so maybe I can leave that until the mass transfer correlation works
The ones produced by my code are much larger than both the random constant value we have been using and the Tuinier et al values. Both of those are around 10^-7, whereas the calculation I'm doing produces a value around 10^1
Yes it technically doesn't crash (it does run to completion), however the gas/bed temperatures level out at 180C rather than the inlet temperature of 300C. This does not happen when I use 'normal' values. It could be a tolerance issue for the larger mass transfer coefficients so I'll try that now. But either way, the Tuinier paper has mass transfer coefficients that are 10^7 times smaller so I'm likely doing something wrong in the mass transfer coefficient calculation
EDIT: I've checked all the terms in the mass transfer coefficient correlation and the only possible term that could be wrong is the diffusion coefficient (for both CO2 and H2O in N2). It is my guess that my units/magnitude is off for this. I need a term in the 10^-8 to 10^-9 range. The term I'm currently using is 10^-4
The terms seem to vary quite a bit across gas and liquid species. Am I right to say I'm looking for gaseous diffusion terms for both CO2 and H2O in air?
casualguitar said:
Will do
Correct.
This indicates that there is something wrong. Maybe something like evaporation or sublimation is occurring without shutting off when liquid/solid is depleted. I don't know. But it can't be 180 C at long times.
Let's see the detailed hand calculation for a typical case. Also, the range of Reynolds numbers that you show for your bed seems very large to me. Please plot the Re vs tank number at a selection of times for a typical case. The only things that should affect the Re are the mass flow rate and the viscosity.
Also, please plot the heat transfer coefficient vs tank number at a selection of times. Also the mass transfer coefficient vs tank number at a selection of times.
The values you gave are in the right ballpark for m^2/s units.
In nitrogen.
Just one question before I do the above - is the right ballpark the 10^-4 one or the 10^-7 one?
Chestermiller said:
-4
I attempted to find the point that the simulation deviates from what should happen (when I change from 10^-8 to 10^-4) however I couldn't.
I'll start on the plots above first thing tomorrow
Will add these in as I do them.
The ##U_b## calculation:
##U_b## = ##\frac{k_p}{d_p/\beta}##
##k_p## = 15 W/m.K
##d_p## = 0.01 m
##\beta## = 10 for spheres
##U_b## = 15,000 W/m2.K
Seems very high?
Doing the plots now
As for the Reynolds Number vs Tank number plot (for inlet flow = 0.5 mol/s), the trend seems to be that initially there is a high Re (t=0), which levels off almost immediately:
This does correspond to the molar flow which jumps up to about 1 mol/s initially and then gradually levels off to about 0.56 mol/s. This flow should surely level off to 0.5 not 0.56 though?
Notes:
As for the mass transfer coefficient and heat transfer coefficient plots - the heat/mass transfer coefficients have been constant in all simulations so far, so all I'm doing is generating the mass and heat transfer coefficients from the Reynolds number etc, which aren't actually used in the simulation as constant values are used
Also one further note, after I changed the ##U_b## value to the new calculated value of 15,000 I also had to change ##U_g## to be a high number (in the thousands) to get the simulation to converge
Doing the mass/heat transfer coefficient plots now
Yes.
casualguitar said:
Notes:
That's OK. We're just checking to see what they would come out to be and to compare them with the constant values that you have used. So please provide these plots. Also, please specify the units.
Chestermiller said:
Yes.
Will provide details on the mass flow calculation
Doing this currently
One further question. Just looking at my ##U_g## calculation. Will we still have the contribution from the bed in the ##U_g## calculation i.e. 1/##U_b## as we had in the previous model where we lumped them, or will ##U_g## just be a function of re, pr, mu, etc? i.e. no bed properties involved
Ug does not involve any bed properties. Ub does. The overall U combines both. This is the same for both models.
Plots of the CO2 and H2O mass transfer coefficients versus position:
And ##U_g## versus position:
The ##U_g## plot seems to return values in a reasonable range. The mass transfer coefficient seems to be too high by a factor of about 1000. I'll confirm if all of the nested values in the ki function are in the right range
EDIT: for some reason the times didnt show up on the ki graphs. The legend is the same as for the ##U_g## plot
These are the values, ranges and equation used by the simulation to recalculate the mass transfer coefficient values (for both CO2 and H2O):
Reynolds Number: 3500 - 7000
Schmidt Number: Approx 0.7 average
##D_{CO2,N2}## = 0.144 * 10^-4
##D_{H2O,N2}## = 0.259 * 10^-4
The equation I'm using:
##k_i## ##=## ##(2.19Re^{1/3} + 0.78Re^{0.619})Sc^{1/3}D_i(1-\epsilon)/d_p##
and it produces values (as in the graph above) of approx 10^-1
Anything obviously wrong with this?
The Reynolds numbers seem reasonable. Also the Schmidt number does seem to line up with BSL. And you say the D values are reasonable. Possibly suggesting that my ##k_i## equation is being used incorrectly? Or that my recalculation of ##k_i## is wrong somewhere (checking this now)
View attachment 304485View attachment 304486
Please show a hand calculation of k for a Reynolds number of 4000.
Is the above (just posted) suitable?
The k values calculated for these graphs with the equation you used seem correct to me. Also, the Ug's seem reasonable to me.
In using the k values, you multiply by the molar density of the gas by the difference in mole fractions between gas bulk and interphase equilibrium at the gas-bed interface temperature to get the molar flux at the surface. Correct?
Not fully following the above, but I think so yes. To use the k values I'm using the molar deposition rate equation which is:
$$\dot{M}_i^"=k_i\left(\frac{Py_i-p_i(T_I)}{RT_I}\right)$$
Where P is pressure, ##y_i## is the gas phase mole fraction of species i, ##p_i(T_I)## is the saturation pressure of species i evaluated at the interface temperature, R is the gas constant and T is the gas temperature. Is this an equivalent to what you said above (if I factor out the molar density from the equation above)?
Chestermiller said:
What is the value of g that they use?
It seems they use these three values (using g as a tuning parameter I think). 1x10^-5 and 1x10-6 fit the data better than 1x10^-7 so I suppose 1x1-^-5 and 1x10^-6 are the g values here
What value did they use in their main calculations? I’ve derived a relationship between their g and our k:
$$k=\frac{1000RT}{M}g$$where T is the temperature and M is the molecular weight of the diffusing species. R is in J/mole-K, k is in m/s, and g is in s/m. What values of k do you calculate at 250 K using M=18 for water and M = 44 for CO2? How do they compare with the values from our correlation?
It looks like they don't really have a 'main calculation' but they do use a range of g values and then conclude that g = 1x10^-6 is the value that best fits the experimental data.
This value of g gives us k = 2.0785/M
which gives ##k_{H2O}## = 0.115 and ##k_{CO2}## = 0.047
Our correlation returns values of ##k_{H2O}## = 0.26 and ##k_{CO2}## = 0.14
They're not the same, but they are in an approximate ballpark range. Is this reasonable closeness? If so that would mean that the mass transfer coefficients are ok and it is something else that is causing the temperature to level out at an unusual temperature
Chestermiller said:
This is certainly reasonable closeness. I didn’t expect it to be this close.
Interesting so the mass transfer coefficients check out, and the ##U_g## (and ##U_b##) values are also ok. The gas temperatures level out at values lower than the inlet gas temperature though so there is still some bug present. Right now I have just 'recalculated' the ##k_i## and ##U_g## values. I could implement them in the actual simulation and see how the output looks? Or do you think it is worth checking for the bug elsewhere before doing this?
You need to determine why the temperature doesn’t get to the inlet temperature first. It must have something to do with the evaporation coding logistics.
The two 'clues':
- The simulation works as expected (gas temperature approaching the inlet gas temperature), when the ##k_i## value is sufficiently small
- The temperature at each point in the bed does not level off to the same value (shown below). This seems like a big hint as for where the simulation breaks. Will take a look
casualguitar said:
The two 'clues':
How does this compare with the results in the paper? What does it look like as a function of position at constant times?
Well here is the gas temperature vs position (for a range of times):
The gas temperature profile seems to stop changing in any significant way after about 2000s. The final range of temperatures across the bed (210K to about 180K) does seem to be significant because as you said its this range that sublimation/desublimation occurs, suggesting that there is something not working with the sublimation/desublimation coding logistics
For reference, here's the time vs gas temperature plot for the 10 tank setup:
I'm now wondering why the evaporation bug would occur across a range of temperatures (210 to 180K), rather than at one specific temperature (as the pressure is constant). It seems slightly more intuitive that the temperature profile of the bed would level out at a single temperature (say 210K), rather than trend towards the profile it has trended towards
