- 23,752
- 5,953
I think there should be an ##\epsilon## in the term of Eqn.1 and no ##\epsilon## in the term of Eqn.4. That assumes that Ac is the cross sectional area of the empty column.casualguitar said:Hi Chet,
Unfortunately the molar flow error didnt fix the output, although it did change it somewhat.
The molar flow out of a tank should have been defined as the below. It was previously this so I must have changed it somewhere along the way:
\begin{equation}
\dot{m}_j = \dot{m}_{j-1} + \frac{\rho_m \Delta z A_c}{T_g}\frac{dT}{dt} - (M_{CO_2}''*A_s)
\end{equation}
Further up in the code ##m_j## is defined as:
\begin{equation}
m_j = \frac{P}{RT_g}\epsilon A_C\Delta z
\end{equation}
So I now have:
\begin{equation}
\end{equation}
which I've implemented as:
\begin{equation}
\dot{m}_j = \dot{m}_{j-1} + \frac{m_j \epsilon}{T_g}\frac{dT}{dt} - (M_{CO_2}''*A_s)
\end{equation}
Just posting this here in case I've done anything crazy there
