Modelling of two phase flow in packed bed (continued)
427 replies · 37K views · last reply
casualguitar said:
Hi Chet,
Unfortunately the molar flow error didnt fix the output, although it did change it somewhat.
The molar flow out of a tank should have been defined as the below. It was previously this so I must have changed it somewhere along the way:
\begin{equation}
\dot{m}_j = \dot{m}_{j-1} + \frac{\rho_m \Delta z A_c}{T_g}\frac{dT}{dt} - (M_{CO_2}''*A_s)
\end{equation}
Further up in the code ##m_j## is defined as:
\begin{equation}
m_j = \frac{P}{RT_g}\epsilon A_C\Delta z
\end{equation}
So I now have:
\begin{equation}
\end{equation}
which I've implemented as:
\begin{equation}
\dot{m}_j = \dot{m}_{j-1} + \frac{m_j \epsilon}{T_g}\frac{dT}{dt} - (M_{CO_2}''*A_s)
\end{equation}
Just posting this here in case I've done anything crazy there
I think there should be an ##\epsilon## in the term of Eqn.1 and no ##\epsilon## in the term of Eqn.4. That assumes that Ac is the cross sectional area of the empty column.
casualguitar said:
Hi Chet, looking further into the CO2 desublimation rate function, these are plots of temperature versus sublimation pressure (the gas-solid curve), and then temperature versus desublimation rate for a range of ##k_i## values, and ##y_{CO2}## = 0.2 (as it is in Tuinier et al).
Note that for the sublimation pressure curve, for temperature values above the triple point temperature (216K), i've used the liquid-vapour curve. Is there an alternative here? We could possibly say: if T is less than the triple point temperature, use the sublimation pressure curve, if T is greater than the triple point temeprature, let sublimation pressure = some large number?
No. You should be using the actual curve, although there is melting at the triple point (along with a latent heat effect) and, above the triple point, you should more properly be using the liquid vapor pressure.
Note that, at the triple point, the equilibrium vapor pressure is 5 bars, and at the critical point, the equilibrium vapor pressure is 74 bars.
Please plot the equilibrium vapor pressure on a logarithmic scale.
casualguitar said:
Edit: just noting the simulation breaks if I let psubco2 = 1000000 for T > triple point temerpature
casualguitar said:
Hi Chet,
Output is looking better now. Only issue really is that we're producing a lot more solid CO2. The profiles look ok though.
I reverted back to an older approach we had, where we used something like their "fudge factor". I also put in the previous correlation for ##k_{CO2}##.
The fudge factor looks like this and only applies for sublimation (not desublimation):
if ##P*y_{CO2}## < ##P_{sub,CO2}##:
##M_{CO2}''## = ##M_{CO2}''##*##(\frac{M_{CO2}}{M_{CO2}+0.1})##
Tuinier uses 0.1 as their fudge factor. I'm using 0.1 also currently. We previously also discussed converting this 0.1 to a value suitable for us (different units), like this:
factor = 0.1*1000*A_C*dz/mW_CO2
As we're now calculating ##k_{CO2}##, we can no longer use this as a tuning parameter, unless I'm wrong. I'm wondering if we can instead use this fudge factor to tune the amount of CO2 produced?
Here's the output from the above. Note the output is a bit rough looking because I have used n=15. The the simulation takes a lot longer to run now so I'll increase this again once we're happy with the output:
Gas temperature profile shows the constant temperature zone:
The amount of CO2 on the bed in kg/m3. Tuinier et al had values closer to 50kg/m3 for 50s and 150s:
Lastly, ##y_{CO2}## for each position. Each position does level out at 0.2 which is the inlet concentration. There is a bit of fluctuation but this is possibly down to the sublimation process (I'll check this):
If this looks ok to you, do you think it is reasonable to use the "factor" to tune the amount of CO2 on the bed to Tuinier et al?
EDIT: If I take out the fudge factor and run it, the output looks like it did before (incorrect). I didn't think the fudge factor would have such an impact!
What the fudge factor does is prevent M from going negative. The amount of CO2 on the bed should always be positive.
I'm concerned about those much higher depositions of CO2 per unit area than the comparison calculation.
FWIW
https://en.wikipedia.org/wiki/Darcy's_law
https://www.wikiwand.com/en/Buckley–Leverett_equation
https://en.wikipedia.org/wiki/Black-oil_equations
The Constitutive relationships need to be assumed or defined to include all fluid properties, such as;
density, viscosity, and thermal conductivity, which may vary with saturation and phase distribution.
In another unrelated question on energy conversion for work done on a conveyor belt, I postulated if one desires maximum power transfer or energy thruput or MPT or max. energy flow with a lossy interface (eddy currents) the minimum energy lost is 50% due to the MPT theorem. I also stated, in theory, if loss resistance is constant , time is irrelevant to efficiency and friction is irrelevant to losses. (not true here for nonlinear velocity related losses)
However, various time constants can be linearized from these complex models for certain assumptions.
FWIW ( TL;DR both threads ) so just a comment.
Hi Chet, my apologies for the late response. Here's the vapour-solid (sublimation) curve, where for temperatures above the triple point temperature I've used the vapour-liquid curve. At the triple point temperature, the vapour pressure is 5 bar. Standard scale and log scale:
Standard scale:
Line plot titled Sublimation Pressure of CO2 vs Temperature: pressure in Pa against temperature in K from about 80 to 400 K, nearly flat near zero up to about 200 K, then rising steeply to about 4.5e7 Pa at 400 K.
Log scale:
Line graph titled Sublimation Pressure of CO2 vs Temperature, with temperature in K on the x-axis from about 80 to 400 and log-scale pressure in Pa on the y-axis from 10^-5 to 10^7; the curve rises steeply, with a visible kink near 216 K.
Chestermiller said:
What happened to evaporation of the deposits? I assume these values are in each tank?
If you're asking if the first plot there is for each tank then yes that's correct
##k_{CO2}## seems to be the main variable impacting the max amount of CO2 desposited on the bed. My thought is that maybe my ##K_{CO2}## calculation is incorrect
Printing the Reynolds number and the ##K_{CO2}## numbers for the simulation, the Reynolds number seems to be pretty constant at around 2500. ##K_{CO2}## ranges from abour 0.2 to 0.3 which I think is in agreement with the plot below:
Line graph of mass transfer coefficient in mol/m²·s against dimensionless Reynolds number from 0 to 10000, with two solid curves for k_CO2 and k_H2O at T=300 K and two dashed curves at T=194.65 K, all rising with Reynolds number.
Here is the equation I'm using to calculate ##k_{CO2}##:
##k_{CO2}= (2.19Re^{1/3} + 0.78*Re^{0.619})*Sc^{1/3} * D_{CO2,N2}*(1-\epsilon)/d_p##
Where:
##Sc_{CO2} = \frac{\mu_{CO2}}{\rho_{CO2}*D_{CO2,N2}}##
Where ##\mu## is in ##Pa.s##, ##\rho## is ##\frac{kg}{m3}##, ##d_p## is in ##m##
and ##D_{CO2,N2}## = ##0.144*10^4## ##m^2/s##
The units clearly don't match up here. I know we previously had a molar density term in here. Let me go through this ##k_i## derivation from the start tomorrow
Standard scale:
Log scale:
View attachment 326838If you're asking if the first plot there is for each tank then yes that's correct##k_{CO2}## seems to be the main variable impacting the max amount of CO2 desposited on the bed. My thought is that maybe my ##K_{CO2}## calculation is incorrect
Where:
Shouldn't the units of k be m/s?
Thats correct. I checked the ##k_{CO2}## units and it seems to be fine. I also printed out all of the solution data to csv/excel to see if there was anything unusual happening in the data that isn't being plotted and there wasn't.
I did find something interesting though - the bed properties have an obviously significant effect on the output, but some properties are not clearly defined in Tuinier et al.
Tuinier bed data:
- 'glass' particles
- 4.04mm diamter spherical particles
- particle density = 2547 kg/m3
- inner diameter x length of bed = 35mm x 300mm
Missing values required for the simulation are:
- thermal conductivity of the particles (doesn't have a significant effect on the output, just used in ##U_b## calculation)
- heat capacity of the particles
- molecular weight of the particles (has a very significant effect on the output, I found an approx value for this online)
- bed voidage (also has a significant effect on the output)
So I found the PhD thesis that this publication is from. It doesn't mention the molecular weight/heat capacity/thermal conductivity. It does give a porosity value of 0.7 for one simulation though (its not the same simulation, but its a very similar simulation to the one in this paper). Nevertheless when I put 0.7 into the model I get similar output to what they got (the max values are similar, the trends are similar, and the width of the CO2 plugs are similar)
Our output:
Line plot titled CO2 Deposit vs Position: CO2 deposit (kg/m³) against normalized position from 0 to 1, with two curves for Time 50s and Time 150s.
Tuinier et al output:
Line graph of mass deposition in kg/m3 against axial position in m, showing H2O and CO2 profiles at 50 s and 150 s; CO2 plugs are wider and shift toward larger axial positions over time.
So maybe they used voidage = 0.7?
Just note I'm using n=10 so that I can run simulations quickly. The output doesnt change much for higher n other than look smoother
The temperature profiles also look generally ok:
Line graph titled Gas Temperature vs Position: temperature in K against normalized position from 0 to 1, with two curves for Time 50s and Time 150s.
Line graph of Temperature [°C] against an unlabelled horizontal axis from 0 to 0.3. Two curves: a solid black 50 s curve and a dashed red 150 s curve, both falling from about 70 and 90 to near -150, with plateaus near -90 and -150.
What are the rules to fine-tuning models? Which parameters here can be used as "tuning" ones if any?
A (very) quick Google search found packing densities from 6% to 78%, which puts porosity at 94% to 22%.
(https://www.google.com/search?&q=packing+density+of+spheres+in+a+cylinder)
Here is one paper that shows packing density below 60%.
https://www.osti.gov/servlets/purl/4518893
And one than shows the packing range is between 6% and 74%.
(https://mathworld.wolfram.com/SpherePacking.html)
It looks like of case of "You pays yo' money an' takes your choice."
Cheers,
Tom
p.s. Even though the subject is WAY outside my field, I have found the thread interesting enough to have followed from its start. It is not often that we see two experts collaborating here.
Just in addition - in order to credibly use this model, I suppose I would need to add the ##H_2O## ODEs back in and tune the model with these included? Then remove them after tuning
This is a matter of your best judgment.
I can add these back in to see if changing the porosity 0.7 in the above plots was just a lucky coincidence. If it wasn't a coincidence then we should see that the ##H_2O## buildup plots are also approximately correct
In regards to fine tuning the above plots (post #398), can we similarly use the number of tanks here to tune to Tuinier et al? Every other variable seems to be tied up in correlations
I'll work towards the above now unless you think otherwise
oIsn't the porosity 0.3?
I think so. This all is not exact representation of reality, right? It's a model approximation.
Thats true, I'll use the tank number then
Hmm. The paper doesn't seem to provide a porosity value. I found the PhD thesis that this publication came from online. In the section about this model, they don't seem to give the porosity value, but they do give the porosity for a number of other very similar simulations (using the same model as is in the paper), and the porosity value they use is ##0.7##. In addition, when I use their value of 0.7 I get those plots in post #398 that are very similar to theirs. Here's the thesis: https://pure.tue.nl/ws/files/3606277/719418.pdf
If 0.7 is reasonable, then all that remains is to increase n until we (hopefully) get the same output as Tuinier
Here are the CO2 deposition and temperature profile plots with n=100, not including the ##H_2O## ODEs:
CO2 deposition plot comparisons (our model, Tuinier model):
Line plot titled CO2 Deposit vs Position, with normalized position from 0.0 to 1.0 on the x-axis and CO2 deposit in kg/m³ from 0 to about 52 on the y-axis. Two curves: at 50s, a plateau near 52 between about 0.2 and 0.3, falling to zero by 0.4; at 150s, a plateau near 52 from about 0.25 to 0.9, falling to zero near 1.0.
Line plot of mass deposition in kg/m^3 against axial position in m, for H2O and CO2 at 50 s and 150 s; CO2 curves form broad plateaus near 52 kg/m^3 that extend further along the axis at 150 s.
Temperature profiles:
Line plot titled Gas Temperature vs Position: temperature in K against normalized position from 0 to 1, with two curves for Time 50s and Time 150s, both falling from about 365-370 K near position 0 to a plateau near 180 K, then dropping again to about 125 K near position 1.
Line graph of temperature in degrees C against an unlabelled x-axis from 0 to 0.3, with two curves: a solid black 50 s curve and a red dashed 150 s curve, both falling from high values to plateaus near -93 and -150 degrees C.
The deposition profiles are very similar. The temperature profile from our model is missing that first almost constant temperature zone at around 40C. I'm not sure what that is. Presumably its the water freezing but the temperature seems to be a bit high. Besides this it looks pretty good
P.s. My apologies for not providing the same units as Tuinier. I'll get this included in the next version that will have the ##H_2O## ODEs included
Here is the output after adding ##H_2O## back in. It looks good in my opinion. I ran for n=50 because n=100 was going to take too long (I'll rerun now at n=100 to get smoother plots)
Gas temperature:
Line graph titled Gas Temperature vs Position, plotting temperature in K (150 to 350) against normalized position (0 to 1) for times 50s and 150s; both curves fall from high values near position 0 to about 125 K or 180 K at the far end.
CO2 deposition:
Line graph titled CO2 Deposit vs Position, with position normalized from 0 to 1 on the x-axis and CO2 deposit in kg/m³ on the y-axis. Two curves: Time 50s rises sharply near 0.1, plateaus near 54, then falls to zero by about 0.45; Time 150s rises near 0.27, plateaus near 54, then drops toward 34 at position 1.0.
H2O Deposition:
Line graph titled H2O Deposit vs Position, with H2O deposit in kg/m³ on the y-axis (0 to 25) against normalized position from 0.0 to 1.0. Blue curve at 50 s peaks near 25 at position 0.04; orange curve at 150 s is a broader plateau near 24.5 between about 0.08 and 0.22, both falling to zero by about 0.35.
Besides plotting the deposition of CO2 and H2O on the same plot, and fixing the scale units, is there anything you see here as being required in order to consider this model now "fit for use"?
I'll start defining some performance parameters for a parametric analysis if not
Gas temperature:
CO2 deposition:
H2O Deposition:
Check of overall mass balances on CO2 and H2O:: cumulative mass in = deposited mass + mass out?
My apologies for the delay. It was quite difficult to extract the values of the intermediate variables (molar holdup, molar flow, molar desublimation rate, etc) from the integrator.
So we have -
Cumulative mass in:
##M_{IN,TOTAL} = \dot{m_{in}}*y_{CO_2, IN} * t\tag{1}##
The total molar amount of CO2 leaving the column up to time t is:
##\dot{m_T}## = ##\int_0^t{\dot{m}_n(t')y_{CO2}(t')dt'}##
Total molar holdup of CO2 in the gas phase:
##M_{CO2} = \sum_{j=1}^{n}(P/RT_j)y_{j,CO2}(A_cdz*\epsilon)\tag{4}##
Total molar holdup of CO2 in the solid phase:
##M_{SOLID} = \sum_{j=1}^{n}(M_j)\tag{5}##
(And the same for H2O)
Using these relationships, we get this output:
Line graph of cumulative CO2 (mol) against time (s) from 0 to 500 s, showing CO2 in rising linearly, CO2 out rising then merging with CO2 in after about 340 s, solid buildup peaking near 0.16 mol then falling to zero, and gas holdup staying near zero.
At long times CO2 in = CO2 out, and at long times CO2 Gas phase molar holdup = CO2 in * number of tanks
And the same trend for H2O, except the times involved are longer as it takes H2O longer to move through the bed:
Line plot of cumulative H2O in mol against time in seconds, 0 to 3000 s, showing cumulative H2O in and out rising, a solid buildup curve that peaks near 0.25 mol then falls to zero by about 1750 s, and a gas holdup curve that stays at zero.
If the above looks reasonable, I was hoping to define some parameters that could assess the performance of this system, before running the simulation for suitable ranges of initial/boundary conditions Possibly:
Captured Fraction:
##\eta = \frac{M_{SOLID}}{M_{IN,TOTAL}}##
In addition I was interested in defining a parameter that measures the total amount of energy required to 'capture' a given amount of CO2. This parameter would take into account the energy required to cool the bed (I should have this from the other model), and also the energy required to send combustion gas to the packed bed (via compressor). The idea being to assess different conditions versus this "energy required per unit of CO2 captured" parameter. If you think this is reasonable I'll make an initial attempt at defining that performance parameter more accurately
Here's an inital attempt -
Assuming here that these variables are the ones we have operational control over:
1. Initial bed temperature
2. Inlet gas temperature
3. Bed pressure
4. Inlet CO2 concentration
5. Bed material
It would be useful to know which values of each of the above variables lead to the largest amount of CO2 captured. We could simply run a parametric analysis here to see that
I think it would be more useful though to know which values of each of the above variables lead to the largest amount of CO2 captured ##\textbf{per unit of energy input}## i.e. how much total energy input is required per unit mass of CO2 captured. In this packed bed system, we've got energy input in two forms:
1. Cooling of the packed bed
2. 'Pressurising' of the hot N2/CO2/H2O stream to pass it through the packed bed
Note here we have been running the model at atmospheric pressure, but we could in theory run it at any pressure up to the triple point pressure (about 5atm), which is why I included energy input #2.
So the total energy would be the sum of these (not defined properly yet).
The 'total amount of CO2 captured' could be defined as the maximum amount of CO2 captured. We have data for the amount of CO2 deposited at each point in the bed at each point in time, so we could simply take the maximum value.
Do you think the above is reasonable? If so I'll start defining the energy inputs properly. Very much open to the possibility of using other performance parameters at this stage if you think of any!
So we have -
Cumulative mass in:
You should also show a graph of yellow + red + green in comparison to blue to show that CO2 and H2O are conserved. Im surprised that the holdup in the gas within the column is so low, even though all the CO2 and H20 exiting the column exits in the gas streams from the final tank.
Captured Fraction:
The fraction captured should pass through a maximum, after which, at some time, the flow should stop.
3. Bed pressure
5. Bed material
These all sound like good possibilities. Once you start playing with the model as if it is a real system, you will get other ideas.
Thanks Chet. Working on this. Will update with progress in due course
Hi Chet - just posting my update here to keep this timeline intact -
My thoughts on the axial dispersion coefficient for model 1 -
My thoughts -
We defined ##l##, the dispersion length, as:
$$l = \frac{\Delta x}{2}$$
We know:
$$\Delta x = \frac{L}{n}$$
Subbling ##\Delta x## in:
$$l = \frac{L}{2n}$$
We also know ##D = u*l##, where D is the dispersion coefficient, so:
$$\frac{D}{u} = \frac{L}{2n}$$
So n, the number of tanks, as a function of the dispersion coefficient (and the equation we could use to find the number of tanks) is:
$$n = \frac{L*u}{2D}$$
Therefore, if I find a correlation for the dispersion coefficient in literature then I can sub this in above. You mentioned we couldnt use a correlation that was a function of the Reynolds number though I dont understand what the problem with using one that is a function of the Reynolds number would be?
Or have I made an incorrect assumption about what it is I'm doing?
Just updating with the mole balance check. Plot of CO2 in vs out+gas holdup + solid holdup:
Line graph of CO2 (mol) against time (s) from 0 to 800 s, showing two nearly overlapping rising lines: Out + Gas + Solid (blue) and In (grey), rising from 0 to about 1.36 mol.
It seems to be ok based on this plot. Also it matches the Tuinier data well:
Line graph of gas temperature in kelvin against normalized position from 0 to 1, with two solid curves for 50 s and 150 s labelled Tuinier et al and two dash-dot curves labelled Simulation Data; temperature falls in steps from about 340-370 K near position 0 to about 125-160 K near position 1.
Line plot of mass deposition in kg/m against axial position in m from 0 to 0.3 m, with simulation curves (dash-dot) and Tuinier et al. curves (solid) for CO2 at 50 s and 150 s; each deposition profile rises sharply to about 52, plateaus, then falls to zero.
Considering the differences between the two models, these are excellent matches.
casualguitar said:
\Hi Chet - just posting my update here to keep this timeline intact -
My thoughts -
We don't define the diffusion length as $$l=\Delta x/2$$We choose ##\Delta x## such that $$\Delta x=2l$$This enables us to use backward differencing to simulate the actual amount of dispersion without explicitly including the dispersion.
casualguitar said:
We know:
According to Freeze and Cherry, l is a characteristic of the porous medium independent of the flow rate.
I saw this also if you're referring to page 390. It defines it as:
$$D = \alpha * \bar{v} + D^*$$
where ##\alpha## is the thermal diffusivity and ##D^*## is the molecular diffusivity.
They extend this to say that ##D = \alpha * \bar{v}## is a reasonable estimate (as you previously defined it). However they don't seem to give ##\alpha## as a function of anything in particular (or reference anyone that might).
Are you saying here that it needs to be determined experimentally, or am I not understanding how we can approximate it?
At a bit of a loss for what to do about the dispersivity - but I did find something possibly useful in this paper by Rastegar et al. They cite some correlations for the axial dispersion coefficient that are not dependent on the Reynolds number : https://www.sciencedirect.com/scien...aLlLLqg7a40zkvohwbhpnLD7a6uZqchExe8QqNC-NCgiI
I was thinking that I could use one of these, and divide by the superficial velocity to get the value of ##l##?
Here are the correlations they mention, where ##D_{ab}## is the axial dispersion coefficient:
First one:
Equation (4): Db = 2Rp*v*epsilon_b / (0.2 + 0.011 Re^0.48), valid for 10^-3 < Re < 10^3, with Rp the particle radius, from the Chung and Wen correlation.
Second one:
Equation (6): D_b = 0.7 D_m + 5 R_p v / (1 + 4.4 D_m / (R_p v)), an empirical correlation for liquid flow in packed beds of spherical particles.
Do you think either of these are valid? If so I'll plot both for a range of superficial velocities
This question of quantifying the dispersion is the last roadblock in the model 1 simulation. After that its just parametric analysis
Ah here we go - I found this in "A Review of Diffusion and Dispersion in Porous Media" by Perkins et al:
Equation 12: E/D0 = 1.75 Ud_p/D0, valid for 2 < Ud_p/D0 < 50, where E is the longitudinal convective dispersion coefficient in sq cm/sec and d_p is particle diameter in cm.
This is on the order of the particle diameter as you said, and is not a function of the Reynolds number. Looks promising?
So since we know ##D=u*l##, I guess we can say:
$$D = u*(1.75*d_p)$$
So:
$$l = 1.75*d_p$$
And using our previously derived ##n = \frac{L}{2*l}##, particle diameter of 5mm and column length of 1m, we get:
$$n \approx 57$$
I'm semi optimistic about the above. Have I done anything outlandish?
Hey Chet,
Just updating here to say the parametric analysis for the CO2 model is in progress. As of now its set up like the following:
Parametric variables: Bed temperature (-170C to -90C), CO2 inlet mole fraction (0.1, 0.15, 0.2), and material (alumina, stainless steel, and silica). The inlet temperature is 100C.
Performance parameters: Specific Energy (cooling energy required per mole of co2 captured), captured fraction (solid co2 divided by total co2 in)
In addition, I'm doing a similar analysis for standard air (not flue gas). So for the same bed temperatures and materials I'll run a CO2 mole fraction of 0.000414 and an inlet temperature of 15C
