Modern Algebra - Finite Subgroups of Q*
  • Thread starter Thread starter ESLASL1
    Algebra Finite
7 replies · 4K views
ESLASL1
Find all the subgroups of Q* (set of all non-zero rational #s) under multiplication. Explain how you know that Q* has no other finite subgroups.
The subgroups must satisfy the properties of association, closure, inverse, and identity.
I have determined that Q+ under multiplication is a subgroup (and is not cyclic) but is this the only one? Would I also include multiples? For example, 6^n where n is an integer under multiplication. How do I know there are no other finite subgroups?
Neither of the subgroups you've found so far is a finite subgroup. I assume you want to find finite subgroups?
You are right. I do want finite subgroups of Q* and neither of the two I mentioned are as such. Thank you for pointing this out. Of course, now I am even more frustrated and unclear as to how to pursue the solution.
Is {-1,1} a finite subgroup?
You forgot about inverses. You may want to consider this question in terms of generating sets, it will probably be easier.
The inverse of 6^(n) is 6^(-n). I think if n is an integer, -n is also an integer.
