clem said:
There are some problematic statements in this paper. Bell's spaceship paradox is based on the assumption, that the acceleration is always simultaneous in the laboratory frame. As correctly pointed out by Franklin, this acceleration cannot be simultaneous in the new rest frame of the rockets. Thus the distance between the rockets increases and the rope, whose rest length is of course unchanged, must break. However, he writes:
Franklin said:
Bell’s paradox was that his intuition told him the cable would
break, yet there was no change in the distance between the ships in system S.
He suggested resolving the paradox by stating that a cable between the ships
would shorten due to the contraction of a physical object proposed by Fitzgerald
and Lorentz, while the distance between the ships would not change. This
resolution however contradicts special relativity which allows no such difference
in any measurement of these two equal lengths.
No, Bell's solution is in agreement with the basic principles of special relativity, which requires the equivalence of all inertial frames of reference, that is, all IS are equally valid for the description of any phenomenon.
a Franklin) In their rest frame, the rest length of both rockets as well as the rope are
unchanged, and since the distance between the rockets
increases due to non-simultaneous acceleration, the rope breaks.
b Bell) In the lab-frame, both rockets as well as the rope are
contracted, while the the distance between the rockets
stays the same due to simultaneous acceleration , thus also in this frame the rope breaks.
There is no need to declare the "rest length" as the only meaningful length, as suggested in Franklin's paper.
This reminds me somehow on the attempts of Rohrlich and many others since 1960, to allow synchronous force and equilibrium conditions only in the rest frame of the measured object, and then create Lorentz covariant expressions leading to "asynchronous" force and equilibrium conditions in all other frames. At the end, all 3D quantities are replaced by 4D's. Though, since the experimental predictions are the same in both versions – that was also misinterpreted in that paper – that doesn't seem to be problematic.
Regards,
