Modified Twin Paradox in Special Relativity
The discussion centers on a modified version of the Twin Paradox within a 2-torus universe, where two observers, A and B, travel along a closed path at a relative speed of 0.9c. The paradox arises when both observers perceive the other's clock as running slower, leading to a contradiction upon comparison. Key points include the challenges of synchronizing clocks in a periodic spatial coordinate system and the implications of frame changes rather than acceleration. The conversation suggests that the geometry of the universe may not be entirely flat, indicating the existence of a preferred frame. The resolution of the paradox lies in understanding these synchronization issues and the nature of the spatial path.
zytsang
The problem statement
Suppose the universe is a 2-torus, thus there exists a spatial path that you will go back to where you start eventually. Let Observer A and Observer B travel on this closed path. Observer B is traveling at a constant speed of 0.9c relative to Observer A, where c is the speed of light.
At time t0, Observer A and Observer B are in the same spatial location and they synchronize their clocks. Then they travel apart. At time t1>t0, Observer B meets Observer A and compares their clock.
Paradox: from the view point of Observer A, Observer B is traveling at 0.9c, thus B's clock should run slower than A's clock; from the view point of Observer B, Observer A is traveling at 0.9c, thus A's clock should run slower than B's clock. Therefore when A and B compare their clock at t1, there seems to be a contradiction.
Question: resolve this "paradox", draw the space-time diagrams for both Observer A and Observer B.My attempt
The lecturer has talked about the Twin Paradox, and I know that the acceleration and deceleration leads to the clock discrepancy. However here I think both Observer A and B are in inertial reference frames, so the clock should not be affected by acceleration. But I just can't find any loopholes in the problem. My experience told me that, the paradoxes in special relativity are always caused by clock synchronization (correct me if I am wrong). Is the answer to this paradox due to the fact that, it is impossible for A and B to synchronize their clocks at t0? Why? Or my attempt is wrong and the solution lies on other aspects?
Thank you for your help!
My attempt
Other aspects is the answer. In the Twin Paradox saying acceleration and deceleration leads to the discrepency is a little misleading. You have the same paradox even if the change of velocity is instaneous. It's just the change of frames that count. You really have to follow the hint and draw the space-time diagram. There are obvious problems with synchronizing clocks when the spatial coordinate is periodic. It takes some thought. The torus isn't quite Lorentz invariant. There is a preferred frame where the radius is maximal. Think about it.
Thank you very much for your reply. But I think in this problem Observer B is always traveling at speed of 0.9c, so there shouldn't be any change of velocity. Can you explain a bit more on "There are obvious problems with synchronizing clocks when the spatial coordinate is periodic"?
How come there is a preferred frame? I thought the geometry of 2-torus is flat, and every point on 2-torus has infinite radius, or am I mistaken?
Draw a space time diagram like the problem suggests. Of course, there is no change of velocity in this case. Think about it this way. Light signals can travel around the space multiple times. This means A can see multiple copies of B. He can only synchronize with one of them, not all of them.
I think what they mean is not really a 'torus' but a 'cylinder'. Just the spatial coordinate is wrapped in a circle. If you shoot a light signal to the right it will travel all of the way around the universe and hit you from the left. What I mean by preferred frame is that there are experiments you can do to detect whether you are moving. So there is an absolute rest frame.
For some discussion of this problem see this thread and this thread. They contain links to published papers on the topic.
10K
