Modify USB ZipDrive power input source - query
The discussion centers on modifying an Iomega Zip drive to operate as a bus-powered device instead of relying on an external power supply. Key points include the need to determine if the Zip drive requires the 5V USB line for data read/write operations, as well as whether isolating the modified 5V line from the existing power circuitry is necessary. Participants express concerns about the current draw from the USB port, noting that the maximum allowed is 500 mA. There is uncertainty regarding the current requirements of the older Zip drive models compared to newer versions, which may have been designed with lower power consumption in mind. A plan is proposed to measure the current draw during operations to assess compatibility with USB power limits. The discussion emphasizes the importance of ensuring that any modifications do not compromise the drive's functionality or exceed USB power specifications.
Ouabache
Homework Helper
I have a USB Iomega zip drive (100MB) that uses both an external power supply and USB cable. Subsequent models of the same drive take power (5V) directly off the USB from the PC. I wish to modify my zip drive to make it a bus-powered device. The external PS measures +5V open circuit. The spec on the external PS transformer is 5Vdc, max 1A
Does the ZipDrive require the use of the 5V USB line to make the data read/write operations to a zipdisk? [/color](the other 3 lines are data+, data- and ground)
Is it recommended to isolate the newly modified 5V line (to Zipdrive PS input) from the line that already goes to Zipdrive circuitry? If so, how?
How can I find out if the PC can supply sufficient current thru USB port for new total load (both Zip's PS and data circuitry)?
(If total current draw is an issue, Iomega may have designed their upgraded model, taking that into account).
glossary of selected abbreviations:
PS - power supply
Zip - Iomego zipdrive
USB - universal serial bus (original, not
2.0)
Computer science news on Phys.org
The max current draw allowed on the USB bus is 500 mA. It's quite likely that the new USB Zip drives are built with motors that draw less than this. Older ones with external power supplies probably have motors that draw more than this.
I haven't been able to locate any specs on current drawn by each of these models. I will put my model on the bench and directly measure the current drawn during read/write operations.
If it turns out that the draw is less than 500mA, are there other considerations that should be addressed, such as isolating the newly modified 5V line (to Zipdrive PS input) from the line that already goes to Zipdrive circuitry?
I came across a video regarding the use of AI/ML to work through complex datasets to determine complicated protein structures. It is a promising and beneficial use of AI/ML. AlphaFold - The Most Useful Thing AI Has Ever Done https://www.ebi.ac.uk/training/online/courses/alphafold/an-introductory-guide-to-its-strengths-and-limitations/what-is-alphafold/ https://en.wikipedia.org/wiki/AlphaFold https://deepmind.google/about/ Edit/update: The AlphaFold article in Nature John Jumper...
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
