Modifying integral so that it matches the table
  • Thread starter Thread starter Saladsamurai
    Integral Table
Saladsamurai
I am trying to integrate:
\int e^x\sin(T+x)\,dx
where T is independent of x. I have the following formula from a table of integrals:
I am a little confused as to how I can use this? The arguments of my functions are not identical so I am not sure how to go about this? Can I actually use this formula?
Just use
\sin y = \frac{e^{iy}-e^{-iy}}{2i}.
You also could use the trig identity for sin of a sum to use the formulae from integral tables.
fzero said:
Just use
hi fzero :smile:
For your latter suggestion: Which trig identity? sine of sum goes to a product of sine and cosine, so my formula would still not apply ...
I would use an ordinary substitution for starters: u = x + T, du = dx. The integral then becomes:
e^{-T}\int e^u\sin(u)\,du
That one can be done using two integration by parts.
Saladsamurai said:
hi fzero :smile:
Yes, but I'd assume there's an analogous formula for the cos integral. You can also use a change of variables u=x+T, for which e^x = e^{-T} e^u.
Ooooo you guys are sneaky!
fzero said:
Just use
This won't help with using the table of integrals.
But, yes, you can use this formula from the table of integrals.
Use the substitution: u=T+x\quad\to\quad du=dx\ ,\quad\text{also gives: }x=u-T
Therefore: e^x=e^{u-T}=e^{-T}\,e^u\,. and e-T is just a constant coefficient.
