Calculating Molarity of a Solution: Aluminum Salt and Unreacted Sulphuric Acid
  • Thread starter zpmodel
  • Tags
    Molarity
In summary, the problem involves dissolving metallic aluminum with sulphuric acid and then diluting the solution. The molarity of the solution with respect to the aluminum salt formed is 0.232M, and the molarity of the resulting solution with respect to unreacted sulphuric acid is 0.326M.
zpmodel
I have problem and can not solve it:
A piece of metallic aluminum weighing 2.50 grams is treated with 75.0 mL of sulphuric acid ( d = 1.18 g/cm3 , 24.7% H2SO4 ). After the metal is dissolved, the solution is diluted to 400mL.
a) Calculate the morality of the solution with respect to the aluminum salt formed.
b) Calculate the morality of the resulting solution with respect to unreacted sulphuric acid.
I made a slight attempt, but got lost after it:
75ml x 1.18g = 88.5g
Xg / 88.5g = .247
Xg = 21.859g of H2SO4
I actually don't even know what I am doing anymore :(
I'm seeking a learning experience so that I can solve other problems as well. Please, any help would be greatly appreciated.
Xg / 88.5g = .247
Im not sure what the morality of the solution would be...but i may be able to help with the molarity...
You have 75mL of 24.7% H2SO4. 75 X 0.247 = 18.53mL of pure H2SO4. 18.53mL X 1.18g/cm3 (density) gives 21.86g H2SO4 X 1mol / 98.078g (molecular weight of H2SO4) = 0.2229mol of H2SO4
Now we have to determine the #moles of aluminum. Assuming Aluminum is purely elemental aluminum, the molecular weight x weight given is 1 mol / 26.98g X 2.50g Al = 0.09266 mol AL
First thing to do in any problem like this is to convert everything to # of moles.
We have 0.2229mol H2SO4 and 0.09266mol Al
The rest is super easy
for part A. you know the number of moles, and amount of solution (0.400L) so 0.09266mol AL / 0.400L = 0.232M
for part B. The amount of H2SO4 remaining (assuming all Al reacted) is 0.2229-0.09266 = 0.13024mol of unreacted H2SO4. so 0.13024/ 0.400L = 0.326M H2SO4.
Hope that helps (and is correct)
First, let's break down the problem and identify the key information given. We are given a piece of aluminum weighing 2.50 grams and it is treated with 75.0 mL of sulphuric acid with a density of 1.18 g/cm3 and a concentration of 24.7% H2SO4. After the reaction, the solution is diluted to 400mL.
a) The first step is to calculate the moles of aluminum used in the reaction. We can do this by using the molar mass of aluminum, which is 26.98 g/mol. So, 2.50 grams of aluminum is equal to 2.50/26.98 = 0.0927 moles of aluminum.
Next, we need to determine the volume of the final solution. We started with 75.0 mL of sulphuric acid and then diluted it to 400mL, so the final volume is 75.0 mL + 400mL = 475mL.
Now, we can use the formula for molarity, which is moles of solute divided by liters of solution. In this case, our solute is the aluminum salt and our solution is the diluted solution of 475mL. So, the molarity of the solution with respect to the aluminum salt is 0.0927 moles / 0.475 L = 0.195 M.
b) To calculate the molarity of the resulting solution with respect to unreacted sulphuric acid, we need to first determine the moles of sulphuric acid used in the reaction. We can do this by using the molarity formula again, but this time we know the moles and the volume, so we can rearrange the formula to solve for moles. 0.247 M = moles / 0.075 L, so moles of sulphuric acid used is 0.247 x 0.075 = 0.0185 moles.
Next, we need to take into account the dilution factor of the solution. We started with 75.0 mL of sulphuric acid and then diluted it to 400mL, so the dilution factor is 400/75 = 5.33. This means that the moles of sulphuric acid used in the reaction is actually 5.33 times more than the calculated value of 0.
What is molarity and how is it calculated?
Molarity is a measure of the concentration of a solution, specifically the number of moles of solute per liter of solution. It is calculated by dividing the moles of solute by the volume of the solution in liters.
What is the difference between molarity and molality?
Molarity is a measure of concentration based on the volume of the solution, while molality is based on the mass of the solvent. Molarity is affected by changes in temperature and pressure, while molality is not.
How does molarity affect the properties of a solution?
The molarity of a solution can affect its physical and chemical properties, such as boiling point, freezing point, and osmotic pressure. This is because a higher molarity means a higher concentration of solute particles, which can change the behavior of the solvent.
What is the relationship between molarity and dilution?
Dilution is the process of adding solvent to a solution, which decreases the concentration of the solute. The relationship between molarity and dilution is inverse, meaning as the volume of the solution increases, the molarity decreases.
How is molarity used in laboratory experiments?
Molarity is a crucial measurement in laboratory experiments, as it allows scientists to accurately prepare and control the concentration of a solution. It is also used in calculations to determine the amount of solute needed for a desired molarity in a solution.
