How Do You Calculate the Moment of Inertia for a Cubic Slab?
To calculate the moment of inertia for a cubic slab with dimensions a x a x a/4 about its symmetry axis, the formula is (ma^2)/12 + m(a/4)^2/12. The discussion highlights the challenge of using integration to verify this result by considering the slab as a stack of thin plates. It is emphasized that the symmetry axis for this calculation should be parallel to the larger face of the slab and through its center. The parallel axis theorem can be applied effectively in this context. Understanding the symmetry and dimensions is crucial for accurate calculations.
jumbogala
A slab has width a, length a, and thickness a/4. What is the moment of inertia about its symmetry axis?
Use the one parallel to the large face of the slab.
The answer is supposedly (ma2)/12 + m(a/4)2/12.
I can't see why so I tried to verify it using integration, but that's not working either. Basically I tried to find the moment of inertia of a thin plate, dimensions a x a. I found that to be ma2/12 like I should.
Then I wanted to basically take a stack of thin plates to make one thick plate of thickness a/4. But I can't figure out what the calculus for that would look like. Help?
Which symmetry axis? It has a couple of them
If you took a notebook sitting on a table, do the symmetry axis parallel to the table and through the center of the the notebook (horizontal). Since it has dimensions a x a it doesn't matter which direction the axis points (ie. in the x or y direction) because they will be equal.
I just do not want the axis that points up from the table (vertical).
I found something on the internet that shows how to do this, but they did not use a "stack". Is it possible to do it by stacking up a bunch of thin slabs?
The corner to corner diagonal is also a symmetry axis, since it's square.
It can be done this way using the parallel axis theorem with integration.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
