Moment of Inertia of this combined system?
The moment of inertia for a rod rotated around one end is calculated as 1/3ML^2, while for a sphere it is 2/5MR^2. The total moment of inertia for the combined system should include an additional ML^2 term due to the need to apply the parallel axis theorem correctly. This theorem requires both objects' axes to be shifted to the same point, which was not done for the sphere in the initial calculation. The axis of rotation is perpendicular to the rod and located at the end opposite the sphere, confirming the need for this adjustment.
jaewonjung
A rigid rod of mass M and length L has moment of inertia 1/12 ML^2 about its center of mass. A sphere of mass m and radius R has moment of inertia 2/5 MR^2 about its center of mass. A combined system is formed by centering the sphere at one end of the rod and placing an axis at the other.
What is the moment of inertia of the combined system?
SumI=I1+I2+I3...
I=MR^2
Moment of inertia for a rod rotated around one end is 1/3ML^2 using the parallel axis theorem
Moment of inertia for a sphere is 2/5 MR^2
Itotal=Isphere+Irod=2/5MR^2+1/3ML^2
However, the answer is 2/5MR^2+1/3ML^2+ML^2
Why is there an extra ML^2 added to the moment of inertia?
So you need to use the parallel axis theorem properly here. When you have compound systems, you need to shift both of their axes to the same point. You have done so for the rod, but not for the sphere. That moment of inertia is still through the centre of the sphere.
Also, always best to shift both separately to the same point and then add, rather than vice versa.
Hope that helps.
Master1022 said:
Just for my understanding, which is the direction of the axis? Just to confirm that it is out of the plane of the rod?
Sorry for not including a picture. The axis is perpendicular to the rod, and is placed at the end of the rod that doesn't have the sphere attached to it.
Hope that helps.
I see. shifting the axis from the center of the sphere to the other end of the rod is ML^2.
Thanks!
