Moment of Inertia for a Decreasing Angular Velocity
The discussion revolves around calculating the moment of inertia for a flywheel as its angular velocity decreases from 650 rpm to 520 rpm while losing 500 J of kinetic energy. The initial poster, Lee, initially miscalculated the angular velocities in rad/s, which were corrected by another user to 68.07 rad/s and 54.45 rad/s. The key to solving the problem involved using the difference in rotational energy, leading to the equation E_final - E_initial = -500 J. Ultimately, Lee calculated the moment of inertia to be 0.600 kg m². The exchange highlights the importance of accurate unit conversion and energy principles in rotational dynamics.
leehufford
You guys might recognize me from a post earlier. Yep, I'm still plugging away at rotation of rigid bodies and have another question.
The flywheel of a gasoline engine is required to give up 500 J of kinetic energy while its angular velocity decreases from 650 rpm to 520 rpm. What moment of inertia is required?
I = moment of inertia
E = (1/2)I(ω^2)
I = 2E/(ω^2)
I converted the rpm's into rad/s. They are 1.13 and 0.91 respectively. Other than that, I sat and thought for a while and couldn't come up with a start. The 500 J obviously needs to be worked in somehow, but this is a change in E not a constant E. Any help would be greatly appreciated.
-Lee
-Lee
How did you get these values for the angular speeds? Remember, rpm means revolutions per minute.
ehild
650 rpm (2pi/1 rev)(1 min/60 sec) = whoops that should be 68.07 rad/sec and
520 rpm (2pi/1 rev)(1 min/60 sec) = 54.45 rad/s
Anyone know how to find the moment of inertia?
You know the difference between initial and final rotational energy.
ehild
ehild
I got it. I did Energy final - Energy initial = -500 J, factored the I out of the 2 terms on the left and got 0.600 kg m^2 for the moment of inertia. Thanks for the hint. I hope I recognize that trick next time I need it!
Thanks,
Lee
Good job!
ehild
