Moment of Inertia: Solving Point A from 3r & 1r Up
To find the Moment of Inertia for point A located at (3r, 1r) in the x-y plane, the z-axis is defined as pointing out of the page. The moment of inertia about the z-axis is calculated using the formula I_z = md^2, where d represents the distance from the z-axis. This distance is the hypotenuse of the right triangle formed by the x and y coordinates. Therefore, d can be determined using the Pythagorean theorem, which yields d = √((3r)² + (1r)²). With this information, the z-axis moment of inertia can be accurately calculated.
Trojanof01
So I have a point A on a graph with x and y axes. From the origin, the point is 3r to the right, and 1r up. I'm to find the Moment of Inertia along the x, y, and z axes. I've found the x and y moments, but not the z and I'm not really sure on how. I'm not getting any ideas from the graph alone. How do I start?
Bump, anybody?
The z-axis points up out of the page. The moment of inertia of the point mass about the z-axis will be
I_z = md^2
where d is the shortest distance of the point mass from the z-axis. Since the point mass is on the x-y plane d will be the distance that the point mass is from the origin. That is it is the hypotenuse of the right triangle formed by its x and y- components.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
