Moments of Inertia: Calculating R & Summing Values
In summary: M at the center. (And it is generalized to I=1/2mR^2 + MR^2+Icm for any geometry, m being a point mass at the center of mass.)Edit: Just for fun I calculated the moment of inertia of a solid cylinder of mass m and radius R, using calculus. I got 1/2mR^2 as expected. (Anyway, that's a long aside, sorry.)In summary, R is the component of the position vector that is perpendicular to both the angular and linear velocity. The moment of inertia of a two-body system is not in general the sum of the individual moments of inertia, but can be calculated using the parallel-axis theorem
StephenPrivitera
363
In general, I=[inte]R2dm. First of all, what is R? R is the component of the position vector that is perpendicular to both the angular and linear velocity. Is this correct?
EDIT: One more question. If we know the moments of interia of say two bodies, how do we find the moment of inertia of the system? Is it simply the sum of the moments?
R is the distance from the axis of rotation to the mass element dm.
No, the moment of inertia of a two-body system is not in general the sum of the individual moments of inertia, because those moments of inertia were calculated about two different axes.
If the axes of the two bodies used to calculate their individual moments of inertia are parallel to the axis of two body system, you can do this: find the distance between those axes and the axis of the two-body system, and use the parallel-axis theorem to recalculate the moments of inertia of the two bodies about this common axis. Then you can sum them.
If the individual axes aren't parallel to the two-body axis, then you pretty much just have to recalculate from scratch.
Moment of inertia is a scalar quantity (analagous to mass) and does not depend on the velocity (though moment of inertia is defined with repect to an axis of rotation, but I don't want to be pedantic.) Basically, r is the distance from the origin (the location of the axis you're calculating for) to dm, that infinitesimal piece of mass.
No (though in many cases, it turns out that way). In general, you will have to use the parallel axis theorem to sum inertias.
Crud, that's twice in a row I answered an answered question; at least my post count will go up.
A few seconds difference, and I would have answered an answered question. :smile:
That's what I originally thought. But when we were doing a problem with torque and pulleys and such today in class, my professor thought differently. There was a mass hanging from a pulley such that it applied a force perpendicular to a radius of that pulley that was parallel to the ground. My professor told me that the moment of inertia of the mass about the axis of the pulley is given by R2M, where M is the mass of the object and R is the length of the radius of the pulley.
For rigid bodies, each mass element moves in a circle about the axis. So linear velocity is of course perpendicular to any line drawn from the rotational axis. For a two body system such as the on just described, the velocity is not necessarily perpendicular to any given mass element.
Is it really meaningful to speak about the moment of inertia of that mass about the axis of the pulley? What are you getting at?
(I suppose at any given instant, if you're thinking of the mass/pulley as a single system, it acts as if the mass is located at the point where the string meets the horizontal radius of the pulley, doesn't it?)
Edit: If you're thinking of the moment of inertia of the mass by itself, that would be constantly changing as r changes. How would you use that?
Blasted 51000 byte maximum... I would have posted my notes for you to see.
Anyway. He solves the problem by considering only the net torque on the system by external forces. If the mass of the object hanging from the pulley is M, then Mg is an external force (considering the mass and the pulley as a system). Other external forces cancel out (eg, mass pulley with tension of support). The net torque is given by t=(Mg)R, where R is the radius of the pulley.
t=MgR=Ineta, where a is the angular acceleration
Inet=1/2mR2 + MR2=1/2R2(m+2M), where m is the mass of the pulley
So, a = 2MgR/(R2(m+2M))=2Mg/(R(m+2M)), which apparently agrees with the result obtained by considering internal forces.
Yes, I see it does work out to exactly the same result both ways. So it is acting as if the hanging mass is attached to the perimeter of the pulley (which does seem to make sense, doesn't it?) (Edit: if you think of it "instantaneously").
That relationship you wrote
I=1/2mR^2 + MR^2 is just what you would calculate for a disk of mass m and radius R with an extra mass M attached at a single point on its perimeter.
So we maintain the definition of I for rigid bodies. That's very good news.
And it doesn't have anything to do with velocity... I guess.
The falling mass's velocity is 0 relative to the point we're looking at.
Which is very hard to comprehend, the more I think about it, since it's position keeps changing.
I'm not sure what you mean by this. Isn't the mass accelerating?
Yes, but at any given instant, that point on the perimeter of the pulley has the same linear velocity and acceleration as the falling mass.
But at each successive instant we have to change our point of reference, so we're always looking at a point at the end of a horizontal radius of the pulley.
It's just a weird way of looking at the problem, but it leads to a very neat solution.
Ah, good point, the point is accelerating too and at the same rate, because
a=R[alpha]=R[tau]/I=2R2F/(R2(m+2M)=2F/(m+2M)
I think that's right - I just learned this - it's all so new
Looks right.
Getting back to magnetism, which is even more baffling...
Have fun.
1. What is a moment of inertia?
A moment of inertia is a measure of an object's resistance to changes in its rotational motion. It is similar to mass in linear motion and is affected by an object's mass, shape, and distribution of mass.
2. How do you calculate the moment of inertia for an object?
The moment of inertia for a point mass can be calculated using the formula I = mr^2, where I is the moment of inertia, m is the mass of the object, and r is the distance from the axis of rotation. For more complex objects, the moment of inertia can be calculated using integration or by using tables of known values.
3. What is the difference between R and summing values in moments of inertia calculations?
R is the distance from the axis of rotation to a point mass, while summing values refers to adding together the individual moments of inertia for each point mass in an object. R is used in the moment of inertia formula for a point mass, while summing values is used for more complex objects.
4. Why is the distribution of mass important in calculating moments of inertia?
The distribution of mass affects the moment of inertia because it determines how far the mass is from the axis of rotation. Objects with more mass concentrated farther from the axis of rotation will have a higher moment of inertia, meaning they will be more resistant to changes in rotational motion.
5. How can moments of inertia be used in real-world applications?
Moments of inertia are used in a variety of real-world applications, including designing vehicles and machinery that need to rotate smoothly, analyzing the stability of structures, and predicting the motion of objects in space. They are also important in sports, such as gymnastics and figure skating, where athletes must maintain control while rotating their bodies.
