Moments problem HELP IM SO LOST
  • Thread starter Thread starter yoda2026
    Lost Moments
The discussion centers on solving a mechanics problem involving moments and forces applied to a stud at points A and B. The user is trying to determine the normal forces at these points given a force of 150N applied at point P. They have calculated moments but are uncertain about the interaction between the applied force and the couple. The suggested approach involves using equilibrium equations, specifically summing forces and moments about points A or B. Understanding these principles is crucial for correctly solving the problem.
yoda2026
ive been trying to figure our this mechanics question and I am rather stuck
but unfortunately i haven't had much experience with moments
find the normal forces applied to the installed stud at points A and B
[PLAIN]http://img851.imageshack.us/img851/1826/photoc.jpg
length from P to A = 360MM
length of A to B = 85mm
thickness of timber between A and B is 45mm (or vertical distance between A and B)
for applied at point P is 150N
ignore friction
formulas
M= f(a+d)=fa
m=fd
so far i understand that the force applied to the centre of the stud
is 360/1000 * 150N = 54NM
then you have a couple of 85/1000 * 150N = 12.75nm
is this the correct way of attempting this question
if so how does the couple and the for applied to the lever interact to give me the force on points A and B of the stud?
The way to solve this problem is to use the equilibrium equations:
sum of forces in horizontal direction =0,
sum of forces in vertical direction = 0,
and sum of moments about any point =0.
Try summing moments about B or A.
