Momentum After Inelastic Collison
In an inelastic collision, momentum is conserved, meaning the total momentum before the collision equals the total momentum after. For the two hockey pucks, their initial momenta are 35 kg*m/s and 7 kg*m/s, totaling 42 kg*m/s. After they collide and stick together, the combined momentum remains 42 kg*m/s. Although kinetic energy is not conserved in this type of collision, the momentum calculation confirms that the final momentum is indeed 42 kg*m/s. Therefore, the final speed can be determined using the combined mass of the two pucks.
NatalieWise123
Two hockey pucks are sliding across the ice in the same direction. One has a momentum of 35 kg*m/s. The other has a momentum of 7 kg*m/s. After the collision, the pucks stick together. What is the momentum of the pucks after the collision?
I'd think you'd just add them together because of the Law of Conservation of Momentum but for some reason I'd imagine they'd slow down after hitting. Is 42 kg*m/s the right answer and if so why?[/B]
Even though energy is not conserved in an in an inelastic collision,
momentum is conserved.
So write an equation for conservation of momentum and solve for the final speed.
Remember, you now have a final mass of 2 m.
