What is the Momentum of a 15 Ton Train Traveling at a Speed of 46.6 m/s?
  • Thread starter Thread starter KatieLynn
    Momentum Train
To find the speed required for a 15 metric ton train to achieve a momentum of 700,000 kg(m/s), the momentum formula (momentum = mass x velocity) is applied. Converting 15 metric tons to kilograms gives 15,000 kg. Solving the equation 700,000 = 15,000V results in a velocity of 46.6 m/s. However, there is confusion regarding the expected answer format, as the teacher indicated a range of "1-10" for the response. This discrepancy suggests a possible error in the assignment instructions or a misunderstanding of the required units.
KatieLynn
What speed must a 15 metric ton train travel to have a momentum of 700,000 kg(m/s)?
Momentum = mass X velocity
change in momentum = mass(Finalvelocity - initialvelocity)
I though you did it like this...
15 metric tons= 15,000 kg
so 700,000=15,000V
V=46.6 m/s
That looks ok to me. Except if you report the answer to one decimal place you'll have to round it up.
Well see that's the problem, my teacher is having us enter our answers on to a university of Texas homework service site thing. So to help us not enter all wrong answers and get a horrible grade, he gave us a "range" for the answers of each problem, for that problem it says the answer is "a small positive integer 1-10"
Well the only thing i can suggest is that there is a typo somewhere. I assume you've checked the units it has to be entered in and everything.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
