Momentum of pendulum at its lowest point
To find the momentum of a pendulum at its lowest point, one must understand the concepts of momentum, kinetic energy, and gravitational potential energy. The pendulum swings from a height determined by its starting angle θ, converting potential energy into kinetic energy as it descends. At the lowest point, all potential energy is transformed into kinetic energy, allowing for the calculation of momentum using the formula p = mv, where v is the velocity at that point. The discussion emphasizes the importance of grasping these fundamental concepts to solve the problem effectively. Understanding these principles is crucial for accurately determining the pendulum's momentum.
xpc123456789
A pendulum of length L swings from rest at a starting angle of θ from the vertical. Assume the mass is concentrated at the end of the pendulum; find its momentum at its lowest point.
Please help, thx:)
Welcome to PF;
The idea is that you have a go to show us where you get stuck and then we can help.
From what you wrote I cannot tell what to help you with exactly - do you know what a pendulum is? What momentum is? Kinetic energy? Gravitational potential energy? Do you know the expressions for these?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
