Momentum physics using vectors.
The discussion revolves around a physics problem involving two colliding blocks, focusing on momentum and kinetic energy calculations. The initial and final momenta of both blocks are to be determined, alongside the changes in momentum and kinetic energy for the system. Participants emphasize the importance of clear notation and vector addition in solving the problem. There is a request for the original poster to provide their calculations to facilitate better guidance. The conversation highlights the necessity of understanding momentum conservation principles in the context of collisions.
logan 1234343
Block 1 (0.5 kg) travels with an initial velocity of [ 60i ] + [ 40j ] m/s and then collides with block 2 (0.5 kg) traveling with an initial velocity of [ -60i ] + [ -60j ] m/s.
After the collision, block 1 has a final momentum of [ 0i ] + [ 5j ] kg*m/s. Assume that no external forces are present and therefore the momentum for the system of blocks is conserved.
What is the total initial momentum of the system of blocks?
i + j kg*m/s
What is the change in momentum for block 1?
i + j kg*m/s
What is the change in momentum for block 2?
i + j kg*m/s
What is the final momentum of block 2?
i + j kg*m/s
What are the initial kinetic energies of block 1, block 2, and the system of blocks?
Block 1: J
Block 2: J
System of blocks: J
What are the final kinetic energies of block 1, block 2, and the system of blocks?
Block 1: J
Block 2: J
System of blocks: J
What is the change in kinetic energy of the system of blocks due to the collision?
J
p=mv
I tried P1x= -10-40*.5
p1y=0
p2x=2.5-40*.5
where i got the final velocity from m1v1 +m2v2 + etc. =m1v1 +m2v2 + etc.
It helps to be clearer about your notation:
If the initial momentum is ##\vec{p}## and the final is ##\vec{q}## then
##\vec{p}=\vec{p}_1+\vec{p}_2## right?
If ##\vec{u}## and ##\vec{v}## are the initial and final velocities respectively, then:
##\vec{p}_1=m_1\vec{u}_1## etc. but in your case ##m_1=m_2=0.5\text{kg}=m## so ##\vec{p}=m(\vec{u}_1+\vec{u}_2)##
Vector addition using unit vectors works like this:
if ##\vec{u}=u_x\vec{\imath}+u_y\vec{\jmath}## and ##\vec{v}=v_x\vec{\imath}+v_y\vec{\jmath}##;
then ##\vec{u}+\vec{v}=(u_x+v_x)\vec{\imath}+(u_y+v_y)\vec{\jmath}##
Rewrite your calculations like this and they'll probably make more sense.
i + j kg*m/s
i + j kg*m/s
i + j kg*m/s
i + j kg*m/s
Are these your answers or just a "template"? Do you mean for each that the answer is supposed to be of the form __ i+ __ j kg*m/s where you are to fill in the blanks? If so, why have you not made any attempt to solve them yourself? Do you know what "momentum" is?
Block 1: J
Block 2: J
System of blocks: J
Block 1: J
Block 2: J
System of blocks: J
J
p=mv
p1y=0
p2x=2.5-40*.5
where i got the final velocity from m1v1 +m2v2 + etc. =m1v1 +m2v2 + etc.[/QUOTE]
So what did you get? Why are you not showing us what you did and what result you got?
Yes this is a "template" for my class. I am to solve for each of the following. I have tried and simply do not understand. I missed this particular class due to illness and haven't managed to understand the material. Least not this part.
My answers weren't submitted because i figured they'd be irrelevant. The computer counted them as wrong. I showed how i got the answers.
We don't understand your working as you have written it - we need to see how you are thinking about the problem more clearly in order to best help you. Did you follow the suggestions in post #2?
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
