Momentum: Skater A & B on Frictionless Ice
  • Thread starter Thread starter runningirl
    Momentum
Two skaters on frictionless ice engage in a push, with Skater A (65 kg) propelling Skater B (80 kg) to the right at 2.0 m/s. The final speed of Skater A can be calculated using the conservation of momentum, resulting in a speed of approximately 1.1 m/s for part a. For part b, where both skaters initially move at 0.50 m/s, the same conservation principle applies, emphasizing that forces do not factor into the calculations. Discussions highlight the importance of momentum conservation in such scenarios, dismissing the relevance of gravitational acceleration. The conversation reinforces the concept that momentum is conserved in both collisions and reverse collisions.
runningirl
Two skaters are standing at rest on frictionless ice. Skater A, 65 kg, pushes skater B, 80 kg. Skater B ends up moving to the right at 2.0 m/s.
a) What is the final speed of skater A?
b) Repeat, but this time, assume both skaters are initially moving to the right at 0.50 m/s.
-F(t1)=F(t2)
-65(v-0)=80(v-2)
v=1.1 m/s for part a.
part b?
hi runningirl! :smile:
runningirl said:
-F(t1)=F(t2)
nooo … force doesn't come into it :redface:
use conservation of momentum (for both parts) …
in collisions (or "reverse collisions" like this), momentum (also angular momentum, btw) is always conserved :smile:
well, p=2.005(v)
how would find v?!
.36=(vf^2-vo^2)/2a
is acceleration just 9.8(2.005)?
(just got up :zzz: …)
runningirl said:
well, p=2.005(v)
how would find v?!
.36=(vf^2-vo^2)/2a
where did 2.005 come from? :confused:
just write a conservation of momentum equation
total momentum after = total momentum before …
what do you get? :smile:
(and gravity (9.8) doesn't come into this … the ice is presumably horizontal! :wink:)
