Motion & Forces: Speed of Block 5.90s After Start
  • Thread starter Thread starter anastasiaw
    Forces Motion
A 5.82 kg block on a frictionless floor is pulled by a force of 12.80 N at an angle of 24.0°, resulting in a calculated acceleration. The horizontal component of the force is 11.69 N, leading to an acceleration of 2.01 m/s², while the vertical component contributes to a separate acceleration of 0.895 m/s². After 5.90 seconds, the block's speed is determined using the equation v(t) = v0 + at, yielding a speed of approximately 12.98 m/s. However, a correction reveals that the correct speed is closer to 11.85 m/s due to a miscalculation in the force components. The discussion highlights the importance of accurately applying trigonometric functions in physics calculations.
anastasiaw
A 5.82 kg block located on a horizontal frictionless floor is pulled by a cord that exerts a force F = 12.80 N at an angle θ = 24.0° above the horizontal as shown. What is the speed of the block 5.90 seconds after it starts moving?
http://img239.imageshack.us/img239/1153/prob49dj7.gif
F = ma
Fx = Fcosθ
Fy = Fsinθ
v(t) = v0 + at
Fx = 12.8cos24 = 11.69 N
Fx = m*ax ax = 2.01 m/s^2
vx(t) = 0 + 2.01(5.9) = 11.859 m/s
Fy = 12.8sin24 = 5.21 N
Fy = m*ay ay = 0.895 m/s^2
vy(t) = 0 + (.895)(5.9) = 5.2805 m/s
v(t)^2 = vx(t)^2 + vy(t)^2 = 11.859^2 + 5.2805^2
v(t) = 12.98 m/s
I entered 13.0 m/s into LONCAPA and it told me it was incorrect. What am I doing wrong?
Edit: Also tried a simpler way:
F=ma
12.8=5.82a
a=2.20m/s
v=v0+at
v=0+2.20(5.9)
v=12.98m/s
The second method is satisfactory.
YOU ARE MAKING A SIMPLE MISTAKE:
cos24 degrees=.9135
>>force=12.80 * .9135 = 11.69N
now a= 11.69/5.82 = 2.009 m/s^2
>v= v0+at
>0+2.009*5.90
>v= 11.854 m/s
